Screws And Spacing For Overhead Drywall?
Old 05-29-2006, 07:37 PM   #1
General Contractor
pdh2100's Avatar
I have a customer working me over about the number of screws in the ceiling on his drywall. He says that it must be screwed every 4 inches or it will fail. We do it basically every 20 over the length on every joist which is on 16 inch centers. Am I wrong for telling him I'm in good shape on this. It just doesn't seem to be an issue.
thanks for the help
paul
pdh2100 is offline
Old 05-29-2006, 07:43 PM   #2
jmic's Avatar
Re: Screws And Spacing For Overhead Drywall?
I'm like old school, but nail ends like every 8" and on the other joists put a nail on each edge and then (3) groups of 2 nails spaced about 2 " apart.
Whats with 20?
Joe
jmic is offline
Old 05-29-2006, 07:46 PM   #3
Custom Builder
Glasshousebltr's Avatar
4 in the field on the walls, 6 in the field on the ceiling. Groups of 2 as jmic mentioned.
Bob
Bob
Glasshousebltr is offline
Old 05-29-2006, 09:43 PM   #4
Teetorbilt's Avatar
Give the dude what he wants. How much extra is it going to cost you?
A happy customer is a paying and repeat customer.
I don't mind saying that I was a PITA when I had my new roof installed. I'm in hurricaneville, hit 3 times in 2 yrs. I insisted that everything was to Miami-Dade High Velocity Wind Code even though I'm in a zone 3 area.
I was also a PITA here, I'm a remod, not a roofer. Tom (aka Grumpy) was a major help as were some others. Tip of the hat here.
The upshot is that everything was done to my specs. and I'm a happy camper knowing that. The customer is always right. Maybe a PITA, but right just the same.
Albert Einstein
Teetorbilt is offline
Old 05-29-2006, 11:19 PM   #5
K2's Avatar
To many screws can break the sheet. That's my opinion but I think I may be right this time.
K2 is offline
Old 05-30-2006, 12:04 AM   #6
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
The way I have always done it for ceilings is 12 inches in the field, 8 inches on the edges, screws only no nails. Float the corners. You can also use a construction adhesive for extra piece of mind.
Like Teetor says sometimes it's just easier to keep the customer happy, but I'm also of the mindset that unless there were conditions preset from the customer before the job starts that you acknowledge, accepted and added into your bill for the extra time needed to accomplish them, this type of micro management is not going to fly. The customer hired you as the pro, he has to have trust in what you do, I don't like the idea of giving up that position of authority as the professional by giving into customers unwarranted worries that might tend to keep snowballing. But that is a fine line you will have to walk.
Mike Finley is offline
Old 06-02-2006, 08:56 AM   #7
Construction Estimator
DaveH's Avatar
Trade: Estimator
Mike is right! 8" edges 12" in field. This is the guidline from all major drywall manufacturers. Glue won't hurt either.
DaveH is offline
Old 06-29-2006, 01:30 AM   #8
Brian
aiocinc's Avatar
Trade: Complete Builder and Remodeler
By current building code for new construction in Indianapolis (in fact, it's the newest standard that was revised the beginning of this year), and what all 3 new home builders require that we do work is as follows. Nails around the perimeter of the sheet only. Screws to be installed on every joist. On standard 4' board, 3 screws are required. On 54" board, 4 screws are required. Hope this helps.
aiocinc is offline
Old 06-29-2006, 09:47 AM   #9
AtlanticWBConst's Avatar
Same measurements with the building codes here (Printed right in the back under the fasteners tables). Only difference from that standard is:
More screws required with 5/8" SR and more with Plaster application (More weight being carried over the surface of the Sheet)
- Build Well -
AtlanticWBConst is offline
Old 06-29-2006, 10:03 AM   #10
DaveH's Avatar
Trade: Estimator
Brian,
I see you are from Indy. I just left the area 2 years ago. What the market like there these days. Who are you buying your rock from..V-line,IDS, R&W, Magnum?
A buck a foot is not an estimate! It's a crap shoot!
DaveH is offline
