Round Corners..Help!!
Old 10-10-2005, 10:18 PM   #1
profinish's Avatar
Trade: painting and drywall
When installing round corners do I run all the way to the floor or do I have to allow for baseboard??thanks for your help
profinish is offline
Old 10-10-2005, 10:24 PM   #2
Teetorbilt's Avatar
Re: Round Corners..Help!!
pro, I run it almost to the floor, we have water issues here.
Base is installed at angles by most. I have the ability to manufacture the most popular profiles in curves. I have seen another company that does this and retails, check the back pages of TOH.
Albert Einstein
Teetorbilt is offline
Old 10-11-2005, 12:45 AM   #3
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
It depends on the final trim. If they are going to use a piece of base cut at 45s to join the two meeting base boards then you bullnose all the way to the floor. (This is the way I see it around here)
Here is the same idea but with crown molding.
The other solution is using Trim-tex like products that transitions the bullnose at the base of the wall.
Mike Finley is offline
Old 10-11-2005, 01:06 AM   #4
Teetorbilt's Avatar
I like the transitions, haven't seen that before.
To be honest, I'm not big on the round corners. Ever see a paint color change using them? Somehow it always looks goofy to me.
Albert Einstein
Old 07-12-2009, 01:40 AM   #5
epat's Avatar
Trade: drywaller
you can put a transition piece on first then cut the bead to fit into it (trim tex) or you can glue one on after to the edge of the bead i prefer the second method. both give you a nice 90. we charge an extra 30 cents a foot for round. finally a step-a-bull will give you a nice paint transition if you want to go with that>
epat is offline
Old 07-20-2009, 10:13 PM   #6
Residential Home Builder
GOTWOOD's Avatar
Trade: Residential Home Builder / Drywall Estimator
looks better with the 22 degree miter in my opinion
GOTWOOD is offline
Old 07-20-2009, 11:07 PM   #7
genecarp's Avatar
TO THE FLOOR
genecarp is offline
Old 07-20-2009, 11:54 PM   #8
Inner10's Avatar
Trade: Control Systems
Rounded corners seem to be pretty popular here, all the NICE homes transition to a pointed corner a few inches before the baseboard and the crown. (like the last pic that Mike posted) The "rest" so to speak do it floor to ceiling.
Inner10 is offline
Old 07-21-2009, 12:46 AM   #9
Rock it...
BattleRidge's Avatar
Most people run the round here all the way down, its cheaper to 45 a piece in there, we charge and extra $11 bucks for every transition. That stacks up in some places.
www.battleridgebuilders.com
BattleRidge is offline
Old 07-21-2009, 08:07 PM   #10
Darren@Partners
Darren@Partners's Avatar
Trade: Drywall Contractor
Trim-Tex just came out with Step-a-bull, has a lip on each side, perfect for busting off the paint color change cleanly. Ooooh I can't wait to have yet another profile of bead to keep on hand.
Darren@Partners is offline
Old 07-23-2009, 12:46 AM   #11
DeanG's Avatar
Trade: Drywall/Stucco
Right!! There was a time when a box of 8' square done a whole house, and now you have to bring 4000 pcs of bead, only to still run short of SOMETHING. The simpler days were much easier!!
DeanG is offline
Old 07-23-2009, 03:10 AM   #12
MZ-HANDYMAN's Avatar
Trade: Custom Home Remodeling 30+ yrs
To the floor it's the job of the trim carpenter to trim around the corner usually he/she will do a 22.5 corner because it sure aint gonna be round!
This picture actually shows you 2 options.
MZ
MZ-HANDYMAN is offline
Question with quarter round haskl33 Carpentry 14 05-31-2008 07:49 AM
Installing bullnosed corners MagnumBI Drywall 3 12-18-2006 08:12 PM
railing corners MinConst Decks & Fencing 12 12-08-2005 08:01 PM
Question about inside corners Lone Wrencher Drywall 36 12-08-2005 07:37 PM
quarter round Ian Flooring 17 11-20-2005 11:57 PM
