Roll On Skim Coat
Old 08-04-2009, 12:18 AM   #1
Worker bee.
dicksdrywall's Avatar
Trade: Drywall
Roll On Skim Coat
Has anyone used either Hamilton Prep coat, or Hamilton Smooth coat before?
What is the difference? Can't get an answer at Home Hardware.
I've got sunlight on glossy paint when a door is opened, and the HO doesn't like what he sees. He's very....discerning.
What I would like to do is rough up the paint, coat the whole wall, sand, then repaint.
Can it be rolled on? It's a reno so there is furniture to trip over. But at least he has A/C!!!
Thanks in advance!
dicksdrywall is offline
Old 08-04-2009, 07:52 AM   #2
Frankawitz's Avatar
Re: Roll On Skim Coat
Not sure about the mud never used it, but yeah you should sand the paint real good and take a texture roller load it up and have at it. then use a 24" knife smooth it out
Frankawitz is offline
Old 08-07-2009, 01:09 AM   #3
Worker bee.
Trade: Drywall
Okay, sanded it with 150 lightly, rolled on thinned mud. The roller skipped in several places and wouldn't stick in others, so I do let it dry a bit before reapplying.
And then the paint began to bubble in four-five places!!!!
Cut the bubbles off, and it looks like the paint wasn't even stuck down.
Shoot me.
Old 08-07-2009, 03:15 AM   #4
capnpat's Avatar
Trade: Framer Handyman
Shoot me.
Would your HO accept a skip trowel or back trowel? both are quick and don't require a hopper and compressor.
capnpat is offline
Old 08-07-2009, 07:04 AM   #5
Frankawitz's Avatar
Where you skim coated were the walls painted? cause if they were that's your problem. mud will not bond to painted surfaces.
Old 08-07-2009, 08:02 PM   #6
Tim0282's Avatar
Trade: drywall contractor
Prime with an oil base primer, then skim the wall with mud and sand, prime and paint. Tough luck there. If you do enough work, these things are bound to happen. Just a matter of time. It's part of our continuing education!
Tim0282 is offline
The Following 2 Users Say Thank You to Tim0282 For This Useful Post:
Big Shoe (12-12-2009), Brocktologist (08-12-2009)
Old 12-11-2009, 05:11 PM   #7
Build it better
rkaitz's Avatar
Trade: General Contractor/Carpentry
Be sure you are useing a good "bondong" primer! Do not skimp here!
rkaitz is offline
Old 12-15-2009, 01:12 PM   #8
drywall icon's Avatar
Trade: painting and drywall
you need to skim the whole wall
drywall icon is offline
skim coat concrete rservices General Discussion 2 06-03-2009 04:56 PM
Skim coat concrete and stamping CrazyTaper Concrete & Paving 8 05-09-2008 02:26 PM
Skim Coat and Doorsets UKframer Finish Carpentry 4 04-20-2008 09:27 PM
Spraying Mud, Skim Coat , Etc... plazaman Drywall 11 11-11-2007 02:51 PM
new skim coat over old stucco 415moto Construction 6 07-12-2006 08:28 PM
