Retaping Wider Than Tape - Drywall - Contractor Talk
Old 09-11-2017, 06:41 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 2,186
Need to run 2 widths of tape over a failed joint, that's been cleaned. I've stayed away from this in the past, but have to do it now. Can't cut the whole thing out and re-sheet the way it should be done.
Is the best course ;
-> Run (1) width [pulling it fairly tight with the compound?] and let dry, then do the next as an overlap?
Or both at same time.
artinall is offline
Old 09-11-2017, 06:44 PM   #2
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,677
Re: Retaping Wider Than Tape
Why can't you cut it out and do it properly?
Easy Gibson
Warren is offline
Old 09-11-2017, 07:04 PM   #3
artinall's Avatar
a) this was the result of a room extension, and joists on this ceiling are hit and miss and hobbled, at best, there is no straight nailer and everything is now concealed - there is a horizontal bow between new and old - and b) it was bid as a patch and repair, for painting, excluding structural movement. And to me it looks like there could be movement between the old beam and the new beam, maybe the way it was attached? Once I open this drum of snakes, I could be doing entire sheets and dealing with going behind crown mould...
Before starting work, it was a simple linear crack, a small fraction of it's present cleared-out width.
artinall is offline
Old 09-11-2017, 07:58 PM   #4
KAP's Avatar
Trade: Custom
Rewards Points: 29,388
Got a pic?
Being this is a patch AND repair, unless you are clear about the limitations of your proposed method, your approach sounds like one that may come back to bite you, which is why you might be second guessing yourself...
Avoid the bites altogether, explain to the customer what your investigation discovered and propose the correct solution... if they don't want to do that, get it in writing, its limitation, and get pics and get them to sign off on the finished product once they're aware in writing...
Case in point... http://www.contractortalk.com/f11/do...action-360474/
KAP is offline
Old 09-11-2017, 08:02 PM   #5
GC/carpenter
Californiadecks's Avatar
Rewards Points: 2,484
Prefill it, slap a piece of tape on it, wipe, slap another peice of tape on it, wipe. Let dry. Then coat.
If it starts, to bulge you can shave it off just before it sets completely up.
Or cut it out and put a piece of rock back in it.
Mike.
_______________
Californiadecks is online now
The Following User Says Thank You to Californiadecks For This Useful Post:
Tom M (09-11-2017)
Old 09-11-2017, 08:04 PM   #6
GC/carpenter
You can also cut it out and pack it with hot mud, let it dry then tape and coat it.
Mike.
_______________
artinall (09-11-2017)
Old 09-11-2017, 08:08 PM   #7
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,016
Pre fill and use this fabric. This is the spun fiberglass not the fiberglass open mesh
https://www.amazon.com/dp/B008RGX178..._t3_B000M2T0VG
Steve
We Fix Houses is online now
The Following User Says Thank You to We Fix Houses For This Useful Post:
Old 09-11-2017, 08:38 PM   #8
artinall's Avatar
I like their regular tape...
Speculating on whether or not this might hold strong enough when areas of attachment wander an inch or so from any common joist?
artinall is offline
Old 09-11-2017, 08:55 PM   #9
The dw pcs - cutouts that run wild - you have to back those up with dw or plywood. Slip the back up behind the existing - hold tight while screwing from the finish side.
Steve
Old 09-11-2017, 09:00 PM   #10
artinall's Avatar
How about drywall adhesive after the fact?
Poke a hole through (at least on the ceiling, and let it settle back near a beam). http://www.liquidnails.com/products/wall-adhesive-DWP24
For walls without adequate support, I don't know...no like I can stuff a 1x3 behind it...or even a metal clip..
artinall is offline
Old 09-11-2017, 09:03 PM   #11
artinall's Avatar
...Slip the back up behind the existing - hold tight while screwing from the finish side.
There's no opening to slip anything through.. by coincidence I finished my prior post before seeing yours...
artinall is offline
Old 09-11-2017, 09:23 PM   #12
I'm not sure I completely understand, but sounds like plaster washers and long screws to stabilize.
Steve
Old 09-12-2017, 06:10 AM   #13
artinall's Avatar
What kind of plastic washers? You proposing getting them to the wall cavity side?
artinall is offline
2 sided masking tape? Home wood Drywall 7 11-29-2015 12:27 AM
Blue tape, suddenly seems useless VinylHanger Painting & Finish Work 37 05-16-2014 06:03 AM
Tape Measures? A-RON Tools & Equipment 54 01-25-2011 09:27 PM
Help. Self Adhesive paper tape problem. jstrand23 Drywall 1 11-28-2007 02:09 PM
