Respray
Old 06-24-2008, 05:54 PM   #1
MUDBUCKET's Avatar
Trade: DRYWALL CONTRACTOR/TAPER
Respray
When scraping old cieling texture (popcorn) ,what kind of procedures do some of you use?this is about a 2500sq ft house ,going to fog/knockdown.
I first polyed all walls and floor,then scraped the ceilings ,wetting them down first.
Now I'm going to roll the poly up off the floor and put down new stuff to get some of the mess out of there.
Next I'll put down drop cloth on the tile floors and a layer of poly on that ,luckily the carpet is gone in most of the house .
Then touch up bad areas and we'll spray Kilz paint to seal the old sheetrock .Then fog it and knockdown.
I'm sure this has been dicussed before ,just wondered if anyone else cleans up after the scraping or just plows through it?
MUDBUCKET is offline
Old 06-24-2008, 06:49 PM   #2
Brocktologist llc.
Brockster's Avatar
Trade: drywall
Re: Respray
Normally you will need to skim the top side of the corners since they prolly didn't pump them and any place you went through the paper or badly scuffed it you will need to coat it with dura bond. Also, they original taper may have only coated the seams just once so check to see if there hollow.
Not sure what "fog it" means...
Brockster is offline
Old 06-24-2008, 07:42 PM   #3
Drywall & Painting Pro
Sir Mixalot's Avatar
Trade: Hang, Finish, Texture, Paint, and Repair.
Re: Respray
After putting the plastic on the floor, I go ahead and put a layer of the lighter plastic that goes on the walls (.31 mil) on top of the first layer of heavier floor plastic. (I just tack it down @ the corners w/ tape.) Then, when I'm finished scraping off the popcorn. I pull up the the layer of plastic on top and have a clean layer undrneath.
Sir Mixalot is offline
Old 06-24-2008, 07:45 PM   #4
Re: Respray
Brockster, Fog it = Spraying a light coat of primer.
Old 06-24-2008, 09:21 PM   #5
Tim0282's Avatar
Trade: drywall contractor
Re: Respray
Does spraying with a light primer help spraying knockdown? We prime after, but wondering if before helps.
Tim0282 is offline
Old 06-24-2008, 09:42 PM   #6
send_it_all's Avatar
Re: Respray
Spraying with primer before texture helps the newly textured areas dry evenly if it was applied over some areas that were painted and others where patchwork has been done. Probably helps adhesion a bit, too.
When I scrape ceilings I try to catch the scrapings in a trash can lid as I go to avoid making a huge mess on the floor.
send_it_all is offline
Old 06-24-2008, 09:51 PM   #7
Re: Respray
On an Popcorn Removal the surface is left very dusty, so the primer seals it so the texture doesn't roll when you knock it down.
It also helps with consistency of the Knockdown. Being that the way the material knocks down is detremined by the surface in which it is applied to. (It knocks down differently on the joints than on the paper of the drywall.)
Old 06-24-2008, 10:01 PM   #8
Re: Respray
Floor after the tecnique above was used.
After Popcorn Removal, Textured, Primed, and Painted.
Old 06-24-2008, 10:48 PM   #9
Brocktologist llc.
Brockster's Avatar
Trade: drywall
Re: Respray
Learned something new today, thanks!
Mixalot, do you use the "Unaggregated" powdered texture for your knock-down? I haven't had the problem of the texture rolling and I'm just wondering if it's because I don't use regular mudd for knock-down?
Old 06-24-2008, 11:18 PM   #10
MUDBUCKET's Avatar
Re: Respray
we use non-aggregate mix for fog and knockdown ,we just mix it thinner and use a differant gun to spray it for fog, it's thicker than primer and helps even out the surface as well as gives the knockdown a better drying suface as opposed to the differance of paper and mud joints when knocking down.
I did plan on touching a bit before sealing it with kilz.
Old 06-27-2008, 05:19 AM   #11
Luke
LukeOR's Avatar
Trade: Drywall
Re: Respray
My thoughts on scraping popcorn / call in sick on that day.......
LukeOR is offline
Old 06-27-2008, 06:50 PM   #12
MUDBUCKET's Avatar
Re: Respray
We finished the job today and it turned out pretty good....I can't call in sick ...I own the company
Old 06-27-2008, 06:52 PM   #13
kgphoto's Avatar
Trade: Residential Remodeling
Re: Respray
Mudbucket,
When you say "Fog" don't you mean apply a light spray of mud and then knock that down as opposed to SirMixAlot's interpretation that you meant a light spray of primer?
To the restL
The "correct" way to texture is to prime before texturing to achieve an even absorption so when you knock down they all smear the same. Many who do quick and dirty or orange peel, will texture first and then prime.
kgphoto is offline
Old 06-27-2008, 06:56 PM   #14
MUDBUCKET's Avatar
Re: Respray
We wet scraped it ,and thats a first for me ,been in drywall for 20 years and never done it that way before,sure cuts down on the dust and is a lot easier to scrape.
Old dogs can learn new tricks.
Old 06-29-2008, 01:47 AM   #15
dhdrywall49's Avatar
Trade: Drywall
Re: Respray
Don't wet the ceiling, put a mask (a good one) or respirator on and fog it on the first day, knock it down the second and be gone. Use Bin after you scrape the ceiling, have lunch, and fog. A good heavy fog will cover most "scratches" and the knockdown will do the rest.
dhdrywall49 is offline
Old 06-29-2008, 10:40 AM   #16
MUDBUCKET's Avatar
Re: Respray
Originally Posted by kgphoto View Post
Mudbucket,
To the restL
Yes when I say fog it's a coat of mud that gives nice even coverage on the whole ceiling ,let it dry completely and spray knockdown on that.
Usually that can be left as finished or can be painted .
Old 06-29-2008, 11:19 PM   #17
Profit is not dirty.
AARC Drywall's Avatar
Trade: Residential Drywall and Taping
Re: Respray
great post guys.. have a few questions of my own..
1. when spraying knockdown, i am using approx 50 psi with a hopper gun. my knockdown seems a bit small for my liking. I have tired to think i need to lower the psi, and my texture is the consistancy of ...pancanke batter. if that helps.
Jay
AARC Drywall is offline
Old 06-30-2008, 02:51 PM   #18
MUDBUCKET's Avatar
Re: Respray
Try lower air pressure or a bigger opening on the spray tip.
Popcorn ceiling falling dumplin1078 Drywall 35 11-08-2006 06:00 PM
