Repairing Pre-Taped Outer Corner
Old 09-10-2017, 09:09 AM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 1,418
This is the lower outer corner (adjoining the ceiling) of a bayed ceiling. A continuous run of about 8' long.
Water had gotten in it a while back and the attached 'tape' on it is a little curled & bloated.
How can that tape be brought back flat? After careful patching underneath and priming, I have 3m spray adhesive, but how can I restore the flatness of it? Will wetting help, I'm guessing this stuff has a memory given it's shape though.
What about cutting it out, which I hesitate to, and using the spray adhesive to splice on a section of new paper tape?
artinall is online now
Old 09-10-2017, 09:35 AM   #2
hdavis's Avatar
Rewards Points: 9,049
Re: Repairing Pre-Taped Outer Corner
Cut it out, and use a narrower piece of tape with spray adhesive. If you use standard width, you'll have problems getting the tape down into the existing bed.
hdavis is online now
artinall (09-10-2017)
Old 09-10-2017, 11:40 AM   #3
artinall's Avatar
Will probably not be able to overlap the tape, as I'd like to.
Old 09-10-2017, 01:04 PM   #4
GC/carpenter
Californiadecks's Avatar
Rewards Points: 8,444
there's no need to get it exactly into the existing bed. Just re-tape it float it out and texture it.
_________________
Californiadecks is online now
Old 09-13-2017, 06:46 AM   #5
artinall's Avatar
Now that I've cleaned it out, it's clearer that the plastic contour is flared out above surface. Need to pre drill a couple tiny holes and hold it down with drywall nails. No other choice.
Old 09-14-2017, 05:53 PM   #6
artinall's Avatar
Taking a closer look at the very shallow clearance, I will have to spray adhesive the plastic and paper tape down to my new patch which is sealed. (tacking the pre-drilled plastic). I think the adhesive should hold the paper to the sealed mud.
Eavestroughing Corner Patterns CdnTrougher General Discussion 1 10-15-2012 11:55 AM
Corner window framing- No post, cantilever. tyler durden Carpentry 9 08-15-2012 09:00 PM
Corner board over the siding or against the building? KennMacMoragh Windows, Siding and Doors 77 07-08-2012 10:01 AM
Black marks left by inside corner applicator AARC Drywall Drywall 5 10-04-2008 08:41 AM
unusual corner capstone to low ret wall henhen11417 Masonry 2 07-03-2008 05:03 PM
