Removing A Popcorn Ceiling?
Old 06-09-2008, 07:38 PM   #1
ChicagoTaping's Avatar
Trade: Drywall Finisher
Hey guys I came across a job, and the customer wants me to remove the popcorn texture. I never came across this so I was wondering if you guys have any tips on a efficient way of taking it off. Is there any special products out there that can loosen it up? Its a living room in a basement that measures 24 feet both ways, with soffits. Its painted too. Any tips will help thanks.
ChicagoTaping is offline
Old 06-10-2008, 02:07 AM   #2
Happy Taper
Mudstar's Avatar
Trade: Mud Wrestler
Re: Removing A Popcorn Ceiling?
rock over it with 1/4'
Mudstar is offline
Old 06-10-2008, 07:37 AM   #3
Professional Remodeler
firemike's Avatar
For regular popcorn ceiling I use one of those pump-up garden sprayers with warm water and a little dish soap and wet an area down, let it soak up good, and it will scrape off with very little effort.
Being as how it is painted, I don't know how well the water will work. You might have to scrape off the painted layer first, wet down whats left, and see what happens from there.
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline
Old 06-10-2008, 07:49 AM   #4
Frankawitz's Avatar
Chicago, Get a razor blade wallpaper scraper, they have them at Home Depot in paint dept, it's a 4" razor blade on a T handle, if the ceiling is drywalled take your time cause it will cut into the board real easy just shave the popcorn off then you should be able to run a palm sander with 80 grit paper. good luck
www.frankawitz.net
Frankawitz is offline
Old 06-10-2008, 07:55 AM   #5
Brocktologist llc.
Brockster's Avatar
Trade: drywall
Porta Cable with at least 80 grit.
Brockster is offline
Old 06-10-2008, 10:20 AM   #6
Nick
pscinteriors's Avatar
I allways use my airless paint sprayer and a bucket of water as hot as i can get it from the tap.Set your pressure fairly low so you dont get too much overspray and soak it down good.(Only works if painted with latex).I use a 10" wide floor scraper with a 5' or 6' handle.Takes it off in sheets.make sure to use some heavy plastic sheeting or tarps on floors and I also bag off the walls for easier clean up.Any thing I cant get off with the scraper I use a drywall pole sander with a medium or heavy grit sanding screen.
Depending on how many times it has been painted it usually comes off real easy. Just make sure to double the time you think it will take in your bid.
Nick
pscinteriors is offline
Old 06-10-2008, 01:08 PM   #7
great tips everyone! I will talk with the guy to see if he wants to rock the ceiling with 1/4 drywall. if not ill quote him on scraping it off.
Old 06-10-2008, 01:14 PM   #8
Doofenshmirtz Evil Inc.
JumboJack's Avatar
That is the worst idea.Just scrape it.
in texas with framing and cornish people will do it for 3.00 a foot. What do yall think about that? Just laber
JumboJack is offline
Old 06-10-2008, 01:33 PM   #9
send_it_all's Avatar
Actually, this is the worst idea.
send_it_all is offline
Old 06-10-2008, 02:12 PM   #10
Brocktologist llc.
Brockster's Avatar
Trade: drywall
Wow, the Porta-Cable drywall sander with a vacuum is the worst idea for knocking down painted acoustical ceilings? Seemed to work well for me the dozen or so times I tried it.
I assume you have no idea what this tool does for you to say such a stupid comment.
Old 06-10-2008, 05:06 PM   #11
1st of all, it's PortER Cable.
2nd, you didn't specify the drywall sander with vacuum.
3rd. The set-up you WERE talking about costs $800. Do you think he should run out and buy it for one job? A 14" drywall knife and 2 gallons of water cost about $10.
Old 06-10-2008, 05:23 PM   #12
Brocktologist llc.
Brockster's Avatar
Trade: drywall
You can rent one from your local rental place for about twenty bucks a day and they do work well for getting past the paint.
And if I could spell correctly I would not have been a stupid drywaller!
Old 06-10-2008, 06:37 PM   #13
Tim0282's Avatar
Trade: drywall contractor
And if we were any good at all, we would move to California. Because that is the way they do it in California. But most every label I read says it will cause cancer in California, so I don't want to move to California. Thank you very much... I'll stay in Iowa and use the Porter Cable sander vac with 80 grit and the stuff nearly jumps in the vac. Then do whatever you want with the ceiling, because it is back to raw drywall. you can check out how the first guy did his drywall. Tools or no tools. Knife or trowel.
Tim0282 is offline
Old 06-10-2008, 06:41 PM   #14
Brock's Avatar
Trade: Residential Remodeler
Only two things come from California.
Brock is offline
Old 06-10-2008, 07:51 PM   #15
kgphoto's Avatar
Trade: Residential Remodeling
Don't forget to test for asbestos so you don't get hit with the $40K fine.
kgphoto is offline
Old 06-10-2008, 09:20 PM   #16
Profit is not dirty.
AARC Drywall's Avatar
Trade: Residential Drywall and Taping
hey all....lets look at this realistically....tear it off and reboard it. Painted popcorn is the worst..boarding with 1/4" will not work, there is no flat surface, and the screws will pop. Sanding it off will work, but it will take longer and more hours than removal and reboarding..and less a lot less dust....
Its up to us as proffesionals, to give the homeowners the best ban for their bucks..and so that we are in an out making the money that we need to survive...so as to this question, it is easier and a quality job to remove and replace...
Jay
ps. thats just my opinion for what is worth...that is what i would suggest to my customers...
AARC Drywall is offline
Old 06-10-2008, 09:57 PM   #17
Not sure why we are re-inventing the wheel here. People have been scraping popcorn off since the dawn of time. If you can sell the customer on tearing out and re-rocking the ceiling, good job, but if you can't, spray the f'n thing with water, let it soak for 15 minutes and then spend an hour scraping. It's so easy a caveman could do it.....they probably F'N did.
Old 06-10-2008, 10:34 PM   #18
jumbocactar's Avatar
Trade: general/remodel
yep ive always just taped up plastic, set my hose nozzle to mist and scraped, sanding sounds lame (never used the setup described) and rocking over should be apparent that'll never do!
jumbocactar is offline
Old 06-10-2008, 11:36 PM   #19
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
I'll fifth that. It ain't rocket science. I garan-T you I can wet and scrape, skim and be done long before any of the other ways even get going.
Mike Finley is offline
Old 06-11-2008, 12:22 AM   #20
newtonswall's Avatar
Trade: drywall
And charge them preeeeeeeeeeeeemium!
newtonswall is offline
Removing popcorn ceiling and wallpaper then retexturing lexter_wolf Drywall 20 05-29-2008 08:46 PM
Painting popcorn ceiling 1stchoice Painting & Finish Work 12 04-13-2008 10:56 AM
Painting popcorn ceiling rocco Painting & Finish Work 14 08-01-2007 10:52 PM
Popcorn Ceiling cowtown Painting & Finish Work 12 03-30-2006 11:00 PM
Removing popcorn on a high pitch ceiling AAPaint Painting & Finish Work 22 02-02-2006 09:53 AM
