Trade: Home Improvments-exterior
Removing Ceiling Texture
what is the best/ easiest/cleanest way to remove ceiling texture from ceilings. Ive got it in my home and hate it. Ive been wanting to take it down for a while and have some time lately to do so any ideas would be great. Thanks
| The Following User Says Thank You to i_plant_art For This Useful Post: | Mr. Mike (01-14-2009) |
#2 | |
Pro Painter
Re: Removing Ceiling Texture
Depends on the texture and if it's been painted or not. Most require soaking with water and scraping to remove. Then you will need to prime, skim, sand, prime, and paint for top notch work.
What are you trying to remove, and what are you wanting to accomplish? Do you want to re-texture with something else, or do you want smooth ceilings?
AAPaint,
You said soak it with water, but would a steamer work? In case I dont want water getting on..lets say..a wood floor or furniture? I know I could cover everything, but would a steamer work at all? Thanks |
Chief Toilet Mover
Trade: Bathroom Remodeling
I'm in the middle of this now, removing about 1500 square feet of pop corn. Lucky none of it seems to have been painted so it's coming off really easy. Hot, hot water in a pump sprayer with a tarp you move around to catch the scrapings from your 14 inch drywall knife is all I usually need. Luckily this is knock-down texture land so if you are at least a little careful and don't dig any deep gouges you don't have to do any skim coating or sanding, the new knock down will cover everything up.
#5 | |
Pro Painter
Peladu, I wouldn't bother with a steamer. It's not hard to control the water with a garden sprayer on mist. Almost everybit of it absorbs directly into the ceiling, then like Mike said, you just scrape it off. I will usually use some 0.013 mil plastic to cover the walls, then some heavier stuff on the floor. After I scrape, I take up the floor plastic, wad up the mess and out it goes. If skimming and sanding are necessary, I lay another floor peice down, get my sanding done, and wrap the whole mess up in one big ball when I'm done. If the job is just ceilings, you can keep the plastic on the walls until priming and painting are done as well. I do ceilings like this with absolutely no disturbance to anything else in the room. Not furniture, flooring, walls, anything.
...jammin
Trade: Rock Disciple
Popcorn, sand? Sanding and skim coating Water and scraping It's messy either way |
I know this could pose as 6 to one and half dozen to another, but I had one job like this and they wanted to eliminate the popcorn stuff, we ended up doing a sheetrock overlay and started from scratch. Only one room and we had it done in a day as far as hanging, tape and mudding so it was'nt like a whole house deal, I could see that running into some bigger doaller amounts material wise.
Never had the misfortune of scraping-knocking loudly on wood right now-but everybody I talked to says it's a miserable job with sore shoulders |
AAPaint, thanks for the reply/input....
#9 | |
Chief Toilet Mover
Re: Removing Ceiling TextureQuote:
thanks guys--ive never had this come up before thats why i wanted to ask. It is a popcorn ceiling. Has not ever been painted. Tried the hot water and 14" knife worked out well. I started in the laundry since it was small ( this is in my own house not for a client) the wife got home saw how easily it was going and got up there and did it for a couple of hours... ( if she would work like this all the time id let her quit her day job!!) so its going pretty good as of right now. THanks for the input guys. We going to skim prime and paint when we are done i just hate the look of the popcorn ceilings smooth is so much clasier looking.
thanks again folks |
Bah Humbug!
A hammer and some new drywall.
What can I say? I am a roofer not an interior guy. |
Chief Toilet Mover
A couple of hours in a small laundry room is a lot of time unless it has been painted or something. Make sure you soak it good and use really hot water, it should come off as fast as you can put your knife up and move it, no back and forth just one smooth motion.
Good luck with it all. |
mike- to clarify some more the couple of hours was the laundry room plus starting on other rooms... were going to do the whole house this way. Sorry for the mislead info.
Here's a system that I came up with about a year ago.
I found a push hoe at a yard sale and put a 1/4" radius on the corners. I duct taped it to my big Craftsman vac with the floor sweep attachment. 95% of the crap comes off dry and there is very little mess. Edges and corners still have to be dealt with, I use a 6" taping knife with the vac nozzle right there. Come back later with the wet sponge.
simpley resheet it with 3/8 drywall Or mix 90 minute durabond in a 6 gallon bucket to a consistensy a little thicker than paint and apply with a paint roller. without sanding apply another coat. after 2 coats take a sanding pole and sand very lightly.
What about removing the texture from a "swirled" pattern on the ceiling?
Brocktologist llc.
Trade: drywall
Sounds like you'll need to "float" it out with a couple of coats.
#18 |
The thing I have always wondered about with using alot of water on sheetrock is that you could cause the paper to pull from the gypsum, and it doesn't show up intil it's repainted. A light spray mist of water should work but you may have some dust, And depending on when the house(Before 1989) was built you have the chance of asbestoes in the popcorn textures. Just make sure you wear a dust mask,
#19 |
Trade: Taper
I know a service guy who does ceiling repairs and he had a guy make him a little gizmo just for this purpose. He took a floor scraper and a mud pan and attached them both together so that the popcorn would fall into the mud pan. It worked really well.
#20 |
Trade: Remodeling / Carpentry
Just did a water damage job. Water from condo unit above. Lab tested the popcorn ceiling 1 hr turnaround $50 so I could start the next morning. 12 hr result $25, 24 hr result $18. Billed the ins co $110 ea for 2 tests.
EMSL is all over the US. Drop off or mail / Fed Ex. Represent yourself as a company or you'll pay a lot more. Steve |
| Prices etc. for texture ceilings | raven2006 | Drywall | 10 | 01-29-2008 05:18 PM |
| removing ceiling fan | navco1390 | Carpentry | 14 | 07-01-2007 01:49 PM |
| Wait to paint ceiling texture: How long?? | steve-in-kville | Painting & Finish Work | 7 | 06-15-2007 08:39 PM |
| Drywall repair - texture matching help | build4Him | Drywall | 2 | 05-29-2006 09:50 AM |
| Removing popcorn on a high pitch ceiling | AAPaint | Painting & Finish Work | 22 | 02-02-2006 09:53 AM |
