QuietRock At Tile Wall Problem
Old 02-07-2018, 11:26 AM   #1
cherander1939's Avatar
Rewards Points: 2
Unhappy
HELP! Our drawings spec'd 5/8" Quietrock, even at bathroom wet walls and tile locations. Quietrock is paper-faced and most definitely not supposed to be tiled over. The drywaller already purchased all the Quietrock pre-cut so we can't get a credit. We also CANNOT add any cementitious board to the Quietrock to be able to tile, as our very expensive glass walls throughout the bathroom are already fabbed and on the way from China. Does anyone know of a solution that does not require replacing the Quietrock or adding cementitious board?
cherander1939 is offline
Old 02-07-2018, 05:32 PM   #2
Spectre's Avatar
Rewards Points: 4
Re: QuietRock At Tile Wall Problem
Schluter Kerdi. It is a very thin waterproof membrane with a surface that is meant to be tiled over.
https://www.schluter.com/schluter-us...-KERDI/p/KERDI
Spectre is offline
The Following User Says Thank You to Spectre For This Useful Post:
AustinDB (02-07-2018)
Cracks in tile and backer board Mltileguy Tiling 26 01-03-2018 08:20 PM
Tile wall for a shower on a pocket door!? sbcontracting Kitchens & Baths 15 12-08-2014 03:53 PM
Need Adhesive to stick Onyx Tile 1x2s to a Glass Shower Wall? steveoneal Tiling 13 01-13-2013 12:27 AM
Glue Travertine wall tile to brick? PB750 Tiling 22 01-10-2011 07:43 PM
