Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Drywall
Old 03-04-2008, 03:57 PM   #1
Trade: taper
problems with 3" premier angle head ?
Hi Guys, greetings from the uk !
When im using my angle head, im getting nice coverage on the wall side but the blade on the ceiling side is taking nearly all the mud off, which i have to go round and touch up by hand. Ive tried all sorts of adjustments but it just seems to give me another problem somewhere else.
Is there a way i can make sure the blades and skids are set correctly. My mates is lovely and loose and coats up perfectly, but then again its 15 years old a nicely worn in.
I know i should be using mine all the time but its to much effort to touch up so i always find myself borrowing his.
thanks in advance.
ajpepe72 is offline   Reply With Quote
Old 03-04-2008, 05:51 PM   #2
Trade: Drylining
You should have bought the Northstar one. They are great. Never taken mine apart, too many bits to lose. I think belmore tools do servicing and rebuilds on corner finishers pretty reasonably. Try them.
Tony M is offline   Reply With Quote
Old 03-04-2008, 07:47 PM   #3
Trade: drywall contractor
If you lay the angle head on a flat table it should lay flat and not rock. If it does, loosen the nose piece and push down flat, then tighten the set screws on the nose piece. Should be fine then. Operative word, should...
Tim0282 is offline   Reply With Quote
Old 03-05-2008, 01:43 AM   #4
Trade: taper
The reason ive got a premier one is because i worked in the lafarge board factory for 14 years and they are the uk distributor for premier gear and got all my kit for next to nothing. I may call them as i think the engineering dept took care of all tool rebuilds etc.
will give the table idea a try.
Old 03-09-2008, 11:12 PM   #5
Trade: spackler--for life it seems like I can never get away from it as there is always work somewhere!!
northstar has a good 3 1/2 inch angle tool, otherwise adjust the tape tech angle tool blades and you should be fine, also make sure you are rolling the tape properly..
Tapingfool is offline   Reply With Quote
How do I cope for an obtuse angle? karma_carpentry Finish Carpentry 9 01-10-2009 08:40 AM
Messed with the 3" head CrazyTaper Drywall 12 03-16-2008 12:57 PM
Tape tech 3" angle head problem. Help! dryrocker27 Drywall 16 12-10-2007 11:49 PM
Best way to attach angle to this? sandyman720 Masonry 6 09-25-2007 07:17 PM
Brick Veneer on steel angle iron sandyman720 Construction 9 07-15-2007 04:20 AM
