Primer/surfacer
Old 01-08-2009, 12:34 PM   #1
Youngster
Cache's Avatar
Trade: Builder / Consultant / Designer
Primer/surfacer
Was considering using a primer/surfacer for the first time and wondering what your opinions were on the various brands.
USG-- TUFF-HIDE
Magnum-- LevelCoat
SW-- Builder's Solution
Haven't gotten pricing for the Magnum yet, but the USG product is a bit pricey. I heard a lot of talk about it being just a bit more expensive than primer. I was just quoted a price of $57 for a pail of Tuff-Hide. That is about what a good primer costs, but the coverage is not even in the same ballpark.
Primer = ~400fpg
Tuff-Hide = ~125fpg
This house calls for smooth walls/ceilings and can absorb the extra $600, but not sure I could routinely justify the upcharge.
The Builder's Solution was quoted at about $70 a pail, but claims the regular 400fpg coverage. I don't hear it talked about much and with such a thin coverage I'm assuming it doesn't do the job all that well.
What do you guys think?
Cache is offline
Old 01-14-2009, 07:35 AM   #2
Butt Expert
Brocktologist's Avatar
Trade: Drywall
Re: Primer/surfacer
BS and TH are both great products but you still have to be a good finisher...
Brocktologist is offline
Old 01-14-2009, 12:56 PM   #3
Youngster
Cache's Avatar
Re: Primer/surfacer
Do you mean that the finish underneath the surfacer still needs to be good? I understand that you still need a good level 4 finish before applying the surfacer, but I thought the surfacer was just a simple spray application and go ahead and paint. Are you suggesting that more finishing is necessary while applying the surfacer?
Cache is offline
Old 01-14-2009, 06:44 PM   #4
Butt Expert
Trade: Drywall
Re: Primer/surfacer
Your right, just do a good clean level four finish and wet sponge any and all spots were you roughed up the paper when you sanded. Better yet, just take a pail of water and one of those wringer mops and mop along all your edges. This will remove a lot of dust and lay back down any paper you roughed up. You can take this advice and use it or stick it in your pipe and smoke it, it's up to you.
Old 01-15-2009, 11:05 AM   #5
Youngster
Cache's Avatar
Re: Primer/surfacer
I'm not a good enough finisher to even do a good level 4 without about 6 coats of mud and a grip load of sanding, but my drywaller is really good. The problem is that it seems that these surfacers are falling between trades. Most drywallers don't have the equipment to spray them. The painters consider it to be part of the drywall so none of them have much experience with it.
Cache is offline
Old 01-15-2009, 09:43 PM   #6
jakester's Avatar
Trade: taping/painting
Re: Primer/surfacer
Your right Brocktologist, you still need to have your walls finished good, we've been using builders solution now steady for over the past year, it is a very good product and sprays out real easy just a light sand after and your done. I recently tried the C.G.C. product, if your looking for a high build product this is the one, just watch your air pressure to much and it sags, but the end result, I think is much better than BS. either way there both good, they both eliminate flashing.
jakester is offline
Old 01-16-2009, 11:04 AM   #7
Youngster
Cache's Avatar
Re: Primer/surfacer
Does BUilder's Solution really have a coverage of 400fpg? What is the C.G.C. product you're referring to?
Cache is offline
Primer/surfacer jakester Painting & Finish Work 14 12-19-2009 01:01 AM
SW primer/surfacer? BobbyD Painting & Finish Work 11 03-13-2007 05:14 PM
