Primer Before Texture Or After
Old 01-21-2008, 08:37 PM   #1
PacNWStructures's Avatar
Trade: Framing, remodeling, new construction
Rewards Points: 25
I hear different reasons for putting primer on the walls before texturing and after texturing. What exactly is the difference? When I had my addition being rocked last year the sheetrocker wanted to primer before he textured but the painter wanted to primer after. I'm sure some of the reason was each wanted the money for spraying. Does the texture stick better if the primer is applied first? Just curious.....
PacNWStructures is offline
Old 01-21-2008, 09:28 PM   #2
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
Re: Primer Before Texture Or After
i've always primed after texturing, but i've heard that the texture could be cut with primer as well, so you now have these three possibilities:
Before
During
After
cleveman is offline
Old 01-21-2008, 09:45 PM   #3
Rewards Points: 25
Haven't heard of that before. I've always primed after texture, just didn't know if there was any advantage to doing it prior of texturing.
Old 01-21-2008, 09:59 PM   #4
Professional Instigator
rbsremodeling's Avatar
Rewards Points: 2,000
My guys mix primer when they texture
rbsremodeling is offline
Old 01-21-2008, 10:38 PM   #5
Painting Contractor
DelW's Avatar
Trade: Painting Contractor
Rewards Points: 250
I've found I get the best results priming before AND after texture.
If love is blind, why do they make Lingerie?
DelW is offline
Old 01-21-2008, 10:57 PM   #6
Rewards Points: 25
best of both worlds....
Old 01-22-2008, 07:45 AM   #7
owner
drywallet's Avatar
Trade: Hanging, Taping, Custom, Repairs, Scrapping
Rewards Points: 75
whats the difference? sounds like someone need to keep busy and somthing to do
drywallet is offline
Old 01-22-2008, 10:08 AM   #8
emer constructi's Avatar
Trade: General contractor
from the USG website
Substrate Priming
Application of a prime coat is necessary to equalize surface porosity.After prepared surfaces have thoroughly dried,apply a prime coat of SHEETROCK Brand First Coat flat latex paint or a good quality interior latex flat wall paint with high
solids content. Prime coat should be applied undiluted and allowed to dry before decorating.
emer constructi is offline
Old 01-22-2008, 10:15 AM   #9
send_it_all's Avatar
Rewards Points: 1,000
It's best to prime before if you are doing a knockdown or skip trowel type of texture because the primer evens the rate at which bare drywall and dry joint compound absorb the moisture from the new texture compound. If you dont prime first the areas where there is compound will suck the moisture out of the texture much quicker than the raw drywall areas. this creates an uneven texture when you try to knock it down. Primer drastically reduces the problem, if not eliminates it.
send_it_all is offline
Old 01-29-2008, 05:31 PM   #10
perfect's Avatar
Trade: Painting and wallpaper
Rewards Points: 75
Is the graco rxt 1500 texture sprayer a decent machine for the odd texture job?
perfect is offline
Old 01-29-2008, 05:38 PM   #11
perfect's Avatar
Rewards Points: 75
can anyone answer my question?
perfect is offline
Old 01-29-2008, 08:50 PM   #12
Tim0282's Avatar
Trade: drywall contractor
I've seen the Graco sprayer advertised, but haven't used it. Should work for smaller jobs. Don't know about whole houses time after time. Wondering how long it would last. Should work great for patching and remodels.
Tim0282 is offline
Old 01-30-2008, 07:22 AM   #13
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,169
The Graco RTX 1500 is a great machine. It has a 15 gallon tank and you can put up to 100' of material hose on it. So yes, you can do whole hoses w/ it.
If you just want to do remodel's and patches I'd say the RTX 1000.
Sir Mixalot is offline
Old 01-30-2008, 03:30 PM   #14
perfect's Avatar
Rewards Points: 75
Thank"s Guy"s
perfect is offline
Old 02-05-2008, 08:06 PM   #15
hangumhigh's Avatar
Trade: Drywall Contractor, Metal Studs, ACT
I just used the 1500 yesterday and it shot orangepeel great but when I shot the knockdown it seem like the air was'nt keeping up. I sure do like the orangepeel it squirts though. I'm sold
hangumhigh is offline
Old 02-06-2008, 04:37 PM   #16
Allen Construction
JJ/Mi's Avatar
Trade: new home construction
Hey Perfect, I've seen it done both ways but we always prime after the texture only because when we set up to paint, we paint. The guys I've seen priming first do so because the uniform color on the wallboard makes spraying an even pattern easier. In decades of doing it this way, we have never had a problem.
JJ/Mi is offline
Pock marks in Orange Peel texture MCComplete Drywall 4 01-14-2008 10:09 AM
Primer questions rebar17 Painting & Finish Work 14 10-25-2007 08:51 PM
2 coats of primer on ceiling rather than paint? Zeebo Painting & Finish Work 20 12-25-2006 12:05 PM
Primer needed on metal garage door??? Zeebo Painting & Finish Work 11 08-19-2006 04:35 PM
Drywall repair - texture matching help build4Him Drywall 2 05-29-2006 08:50 AM
