Trade: Basement Finishing
Primer Before Texture?
This may seem like a no brainer. Joint compound will call out for the surface to be primed before the texture is applied. I know that most of the builders here in Kansas City are skipping this step. Is this only to maintain a uniform color? What do you guys know?
Re: Primer Before Texture?
I normally don't, but that's only so I can make last minute changes to the mud before texturing goes on. I sub out the texturing, so I like him to look at it, and make whatever corrections he needs.
Trade: master painter/finish carpenter/drywall finisher
is it raw drywall or a repair? what type of texture...hand or spray? are you painting after texture?
Trade: Home repairs,drywall,trim.
99% of the time...... no! Who reads directions? Where are you reading this, on the can? Now I'm going to read all that stuff on the side of my can today.
Why wouldn't you prime first? Makes life a lot easier when you screw up your texture and have to scrape i off...
| The Following User Says Thank You to wedoanything For This Useful Post: | Girlscanbld2 (02-19-2010) |
Trade: carpenter
I've never seen anyone spray texture without first priming. I would think the difference between mudded areas and the DW paper would show up.
#7 | |
Full Service Renovations
Re: Primer Before Texture?Quote:
Re: Primer Before Texture? Wow, that just shows you how differerently things are done. I've never worked on ,done,or ran jobs,that we primed before texture. My spay guy would kill me if we primed first.Exceptions are existing glossy surfaces and questionable bonding situations on patched areas. If you orange peel,knockdown ......Do you prime that again before paint? I hope so. Yes you see the drywall through the tex. in the field. We prime and paint after. We are all right in our own minds.
My drywall guy always has primed before texturing. Never asked him why and he has done it this way for me the last 10 years.
| The Following User Says Thank You to Kgmz For This Useful Post: | ebaygolfer (03-08-2011) |
Smart phone? Scan me!
Trade: Painting/Framing/Drywall
that's cause they are too busy trying to drive the jobs $$ down to nothing.. then they have to skip major steps in the process to make up for their hack priced ways. We are in the same city, I know.
Re: Primer Before Texture? |
| The Following User Says Thank You to Big Shoe For This Useful Post: | drywallnflorida (03-08-2011) |
Trade: carpenter
ive always primed first..to begin with it helps to keep the the drymud from bleeding through , the mudded places will soak up alot of what you put on first..wich will enable you to see these areas clearly ..so yes prime first. that is if you like to be called upon again by the home owner..for more work and have your name passed on in good faith to his friends and neighbors.. plus if you dont prime first you will just end.up havin to put on two coats of finish paint /texture..... anyway thats my take on it...
Trade: carpenter
sorry had to break for a second anyway...prime first ...always thats like learning to walk before you run, pretty standard stuff ....if you dont it will come back to bite you ..in the @$$....now i have seen it done where you can use a flat paint..in the place of primer or as a substitute if thats what you all are talking about ?
Remodel & Repair
Trade: Remodel and Repair Services
We always prime first allow drying time and then spray texture.
| The Following User Says Thank You to carolinahandyma For This Useful Post: | ebaygolfer (03-08-2011) |
CM, LEED AP, Attorney
Trade: Construction Management / Real Estate Law
Read the manufacturer's recommended installation proceedures and the project specifications. Those sources will give you unbiased definitive answers.
Twenty plus years of experience means you've seen many things and have more to see. |
it is what it is
We always prime before the texture goes up. If not you run a high chance of the tape lines photographing. This is very true in a room with a lot of windows.
Aficionado
I have never primed prior to texture. Depends how deep your pockets are on the choice you make
Long ago, I’ve been told, God said, “Let there be Contractors. And so they never forget who they are in My creation, let them be damned forever to hire people exactly like themselves.” God called those people Sub-Contractors. How Much Does it Cost to Build a House | Build Your Own Home[B][I] |
#18 |
Trade: drywall contractor
I have rarely primed before texturing. Don't see the advantage. You would still have to prime after texture, if you prime before. Just don't get why it stops the telegraphing. If you prime over texture, doesn't that stop the joint flash? Why would it stop the flash before and not after?
| The Following User Says Thank You to Tim0282 For This Useful Post: | Big Shoe (02-20-2010) |
#19 |
never heard of primeing before texture. You talking just texture or the drywall finish? Only drywall contractor to do that was also the painting contractor so he was just saveing a step. But then whay do us southerners know, And I'm just a trim carpenter anyway
#20 |
I've dealt with 3 spray co. in the last 20yrs. no primer first ever. Whole houses,new construction. Spray-prime-paint.(tinted primer)
Now if all walls and ceilings are going to be white you could get away with priming first. Am I thinking wrong that the texture should be primed before color? Does'nt it need to be sealed. Or do you just do 2 coats of color. We need to check with the painters. |
| Bathroom, peeled wallpaper, need to texture n paint | Red Adobe | Painting & Finish Work | 5 | 02-18-2010 07:59 PM |
| Ceiling texture fun!! | EricTheHandyman | Drywall | 2 | 04-01-2009 10:14 PM |
| can't get rid of bad primer smell....help please | Zeebo | Painting & Finish Work | 17 | 12-10-2008 06:39 AM |
| primer before texture or after | PacNWStructures | Drywall | 15 | 02-06-2008 05:37 PM |
| Primer questions | rebar17 | Painting & Finish Work | 14 | 10-25-2007 09:51 PM |
