Porter Cable 7800 Drywall Sander
Old 10-20-2006, 10:35 PM   #1
xtremekustomz's Avatar
Trade: Flooring, Drywall, Painting
Anyone use this sander? I've been using one lately and have only been able to find foam pads with velcro on them. After about 15 minutes of use the velco comes off of the pad. Anyone else have this problem?
xtremekustomz is offline
Old 10-21-2006, 12:55 AM   #2
theworx's Avatar
Re: Porter Cable 7800 Drywall Sander
Rented one once and obviously didn't figure out the right way to use it. I ruined my nice taping with swirl marks and scuffed the paper on the drywall. And I was trying to apply light pressure. Didn't use it long enough to have the velcro let loose (my experience lasted about 5 minutes). That was enough for me!!!
theworx is offline
Old 10-21-2006, 09:09 AM   #3
Drywall finisher
dumplin1078's Avatar
Trade: Drywall
I absolutely love mine. This thing has increased our speed so much more $$$$ . I have been using the Norton backer pad with velcro paper. I used it for about five or six jobs then it came apart. But I think I hit the edge of an electrial outlet (remodel job switches already installed) when I picked it up off the wall it just flew across the room. As far as swirl marks I have no problem with that. I have in the past when using paper that was more aggressive than 120. If you can figure them out you will never go back to the idiot sticks. When my backer pad came apart the other day I didn't have a spare I almost cried when I had to break out the pole sander. The dust collection is awesome too. I sanded a patch in a customer's house a couple weeks ago with all the furniture and everything in the room uncovered no dust to speak of when I was done.
"I hate to tell you this, but you're a man. You're going to spend your life gettin' up one more time than you get knocked down." John Wayne
dumplin1078 is offline
Old 10-21-2006, 11:20 PM   #4
Well I normally do things by hand but I took on a job that was about 3600 sq ft this week and was working alone so I needed something faster to sand with. I really bit off more than I could chew to tell you the truth. The house is probably 80-90 years old and ceilings were 11 ft high. I had to fill in around windows and doors as well. I have no automatic tapers or anything like that so all taping and mudding was done by hand. There was a crew that came in and put it up and man they loved to use screws. On average there were 50 screws in each piece. I honestly think it was overkill. As for the sanding pad, I went through 3 on this job and the last one came apart and I got tired of buying them so I stapled the velcro back to the foam pad and continued working. As for sanding marks, I didn't have any and I was using 80 and 100 grit. It is a little tricky to use at first but once you get the hang of it, it is a time saver. I got wore out sanding ceilings though. the rooms were about 16x16 so there were lots of screws and joints. What I liked best about it was the sanding of butt joints and tapered joints. As long as you have a fairly thick line to work with the sander acutally creates a suction and sands much faster. But anyway...maybe I just got ahold of some bad pads or something.
Old 10-22-2006, 01:09 AM   #5
Drywall finisher
Trade: Drywall
You can get a bad pad sometimes. It happened to me yesterday. First one out of the box and it caused the sander to vibrate, and was leaving scratches, changed the pad and it didn't happen again.
Old 10-22-2006, 09:21 AM   #6
krobinson's Avatar
Trade: Drywall & Interior Systems
xtremekustomz, is that the Norton hook and loop systems you are having trouble with?
Kim
Lnk to Norton hook and loop: http://www.all-wall.com/acatalog/Nor...ding_Discs.php
krobinson is offline
Old 10-22-2006, 10:55 AM   #7
Kim
I don't know exactly what pad it is. I'll have to look when I get back to the jobsite but I know the actual foam pad is dark grey.
Old 02-12-2007, 01:44 AM   #8
eastonsmith's Avatar
Trade: drywall/remodel
i have a four man sanding screw, among other work going. they use nothing but porter cable sanders. the pads are a bit tempermently, they must be completely centered or bad things happen. also every now and then they come messed up in the box. besides that never use anything tougher than 100 grit, make sure you cut an x in the middle of the disk so that the center isn't sucked to the wall.(and leave you those lovely burns) also dont start the sander on anything higher that 2-3 or you get those nice "swirls". in general power sanding is the way to go, if you do remodel get a porter cable vac. completely dustless. dont use a shop vac., you'll just ruin the shop vac.
eastonsmith is offline
Old 02-12-2007, 03:47 PM   #9
phinsher's Avatar
Trade: Paint and wallpaper
We use the porter cable and love it. We use it on a smaller scale than most of you guys but have found that using a finer grit paper eliminates the swirls. We've had a few problems with the pads, but all the problems came from hitting something and the pad flying apart.
If you're tired of the standard pole sander and don't like or can't afford the Porter Cable, try one of the Radius 360's. They sell them in my local Sherwin Williams and they are a huge improvement over the old pole sanders.
phinsher is offline
Old 10-12-2009, 11:04 PM   #10
polishguy's Avatar
Trade: home improvements
just got mine in the other day and used it on the ceiling it is the best thing ever. well worth the $800 with the vac little to no dust the HO loved it. i think he was more excited about it than i was. it does take some practice.
polishguy is offline
Old 10-13-2009, 12:34 AM   #11
MeatBallDryWall's Avatar
Trade: Residential & Commercial Hanger/Finisher
I was about to suggest the same thing. These things beat the ***** outta the old idiot sticks by far. I owned a PC 7800 with vac & hated it. I also didn't take enough time to really learn to use it either. Mine would leave UNGODLY swirls with 220 paper & a guy with a few yrs exp running one as his dad had the 1st one around our area. But Daymn was it fast. Me & this guy could do 300 sheets, slick with 2-3 ceilings 12ft + within maybe 3 hours out the door. He would machine & I would hand sand/touchup. I'd rather skim once more, brush it off & call it a day now.
MeatBallDryWall is offline
Old 10-22-2009, 09:17 PM   #12
517group's Avatar
Trade: Drywall
what would be the learning curve. i've been looking into it but might have to try it out.
517group is offline
Old 10-22-2009, 11:33 PM   #13
Capt-Sheetrock's Avatar
Trade: Drywall
I have 3 of em, got the first one in 97. I love em and I won't pole sand unless its just a closet. If your wobbling, you have the pad off center, got to pay attention when you put it on, kep it centered. hitting a box or widow, or anything like that will tear off the pad or wrinkle it making it wobble just like being off center,,, its kinda like balancing a tire, if it gets off balance, you will know it. Swirls are caused by not having learned how it handle it, just keep at it. I stick a broom handle in the end of it for high ceilings, and can sand a 14ft ceiling from the ground. I use screens from Johnson abrassive, I get em from all-wall and just install them over a regular pad (I pick them up from other guys that still use them and leave the old ones laying around). I haven't used the velcro ones so I can't say bout them. but i can get around 400 plus from one screen, given that I don't hit a box or such
Capt-Sheetrock is offline
Old 10-23-2009, 05:41 AM   #14
Big Shoe's Avatar
Trade: Home repairs,drywall,trim.
For you guys that want to ease the pain of buying a new one, keep your eyes on craigslist and you can pick on up cheap! I picked up a sander for 100.00 and then another sander,vac with all attatchments for 175.00
Big Shoe is offline
Old 10-23-2009, 06:01 PM   #15
Drywalller's Avatar
Trade: Drywall
EBay also has some great deals,
I have 2 sanders and vacuum setups just in case one fails,I wouldnt sand any other way,Bought one when they first came out and still have it,rebuilt the sander 4 or 5 times(driveshaft,bearing )They really take some abuse and are very reliable.
I only use 220 grit and very good results,I also hand sand after to catch any scratches.
Drywalller is offline
Old 12-03-2009, 03:49 AM   #16
slowforthecones's Avatar
Trade: scab
I've got a question about these PC 7800 drywall sanders. I've seen the new ones without the vac for around $500. Say I already own a nice shop vac...what difference are the PC extractors/vacs?
slowforthecones is offline
Old 12-03-2009, 08:05 AM   #17
Drywalller's Avatar
Trade: Drywall
The difference is the filtering aspect.The porter cable has a car like filter and the actual bag is another filter,So it has dual filtration and thats what it needs,As drywall dust is nasty on any vac motor.
I also use a hardwood flooring edger bag instead of buying the 5 pack of pc bags/It just ties on and you can empty it every so often and have used it with no problems for about 10 years.
The Following User Says Thank You to Drywalller For This Useful Post:
slowforthecones (12-03-2009)
Old 12-03-2009, 11:07 PM   #18
Trade: scab
I meant to ask what's the difference between the PC Dust Vac vs. Dustless Technologies (loveless) Vac?
Pros and Cons of the PC 7800 vs. Dustless with Drywall sander?
Old 12-04-2009, 02:29 PM   #19
Mickey
mickey69125's Avatar
Trade: residential remodeling
I have the PC 7800 and the Loveless vac and like them both. The Loveless has two filters plus a bag, and it has a small lever you can pull up and down and knocks dust of the main filter. Not as good as taking it out and cleaning it, but gets you by for the day. One problem I had recently, I was into Menards and they had the pad with the velcro and 5 discs for $15. Thought I'd try it as it's much cheaper than the regular pads, they're anywhere from $8 to $10 each here. Anyway the foam pad is thicker than the regular disc and when I hit the ceiling with it, I had dust everywhere. Took me a minute to figure out that the pad was keeping the sander to far from the ceiling and the vac wouldn't pick up the dust. Good thing I had one regular pad left. Lesson learned.
I always learn more by listening that I do by talking.
mickey69125 is offline
The Following User Says Thank You to mickey69125 For This Useful Post:
Brocktologist (12-04-2009)
Old 12-15-2009, 01:44 PM   #20
drywall icon's Avatar
Trade: painting and drywall
your putting to much presure on the sander , must be a bad finish
drywall icon is offline
porter cable palm belt sander Bone Saw Tools & Equipment 5 04-18-2007 06:47 PM
porter cable drywall sander tgates Contractor Swap 5 01-24-2007 09:51 AM
Kreg Jig K2 vs. Porter Cable 550 OlTrimguy Finish Carpentry 8 09-18-2006 08:22 PM
Porter Cable Framing Nailers Reno Tools & Equipment 10 05-04-2006 11:44 AM
GREAT Custome Service from Porter Cable JPV123 General Discussion 3 04-06-2006 09:06 PM
