Porter Cable 7800 Drive Shaft
Old 04-13-2010, 10:49 PM   #1
non_cents's Avatar
Trade: interior finish, drywall
Question for all the guys that use the porter cable 7800. When u change the drive shaft in the sander, porter cable insists that you use their expensive grease. Well when I tried to get some of it and nobody that sells parts had it. That led me to the conclusion that most people probably werent using it. So what do you guys use to lube your drive shafts? I know I shouldnt have written that but couldnt resist.
non_cents is offline
Old 04-14-2010, 08:02 PM   #2
Capt-Sheetrock's Avatar
Trade: Drywall
Rewards Points: 250
Re: Porter Cable 7800 Drive Shaft
I use their grease. I ordered it from all-wall, I have three porta=cables, and one tube of it will last me past my lifetime, just brake down and order you a tube of it.
Capt-Sheetrock is offline
Old 04-14-2010, 10:18 PM   #3
non_cents's Avatar
yea thats what I was inclined to do. money wasnt the issue. It was time. The shaft broke and I replaced it but had no lube. None of the companys had it in stock and I needed to use the tool. It was a week to ten days for the stuff to come in. That stuff is SPECIAL!
Old 04-14-2010, 10:56 PM   #4
solar guy
naptown CR's Avatar
Trade: solar contracting
Rewards Points: 1,000
KY works well also and is readily available
naptown CR is offline
Old 04-15-2010, 03:36 AM   #5
Grand Rapids Remodeling
Paulie's Avatar
Rewards Points: 2,052
I hear there is a new KY intense that makes the shaft spin a lot faster thereby increasing the vacuum suction around the sander head for a more pleasurable sanding experience.
Paulie is offline
The Following User Says Thank You to Paulie For This Useful Post:
Capt-Sheetrock (04-15-2010)
Old 04-15-2010, 10:44 AM   #6
non_cents's Avatar
Ha ! I asked for it didnt I. The problem with that KY intense is that it HEATS up the shaft ! Isnt that what we are trying to aviod. LOL. Im sure that this thread will be closed soon.
Porter Cable 7800 Drywall Sander xtremekustomz Drywall 33 01-28-2010 12:00 AM
Porter Cable cleat nailer? mattsk8 Flooring 1 12-28-2009 03:48 PM
Porter Cable 371K 2 1/2" x 14" Compact Belt Sander dayspring Tools & Equipment 7 08-19-2009 01:51 AM
porter cable compact belt sander woodworkbykirk Tools & Equipment 17 05-03-2009 08:05 PM
Shop Vac w/Porter Cable 7800 Norrrrrrrrrrrrm Drywall 22 04-27-2009 12:28 PM
