Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Drywall
Old 02-08-2009, 10:26 PM   #1
SANDBLASTING & REMODELING
plazaman's Avatar
Trade: SODA BLASTING & REMODELING
Popcorn Ceiling Removal / Laminate Ceiling with 3/8?
Out of the 2 mentioned, which would be a cheaper method?
I am currently working on a flip houses where owner decided to go with smooth ceilings, (despite being painted already, and walls primed already.
Would it be cheaper to scrape and skim the ceilings or just to laminate it with 3/8s board?
Please bear in mind that these projects, we work on a budget to get houses in sellable conditions where workmanship/quality are not always up to par.
Thanks
www.perfectocorp.com
plazaman is offline   Reply With Quote
Old 02-08-2009, 11:08 PM   #2
Never lost a battle.
ScipioAfricanus's Avatar
Trade: General contractor, designer, drafter.
If the ceiling is in good repair then just scrape, scrape, scrape. Wet the ceiling first if at all possible, I use a hand operated pump water sprayer with warm water. Let that soak for a while, then start scraping. Even if it has been painted the water will work its way through (at least somewhat).
If you apply 3/8 you have pay for material, fine the ceiling joists, tape and mud and sand etc.
Usually I find I need to tape and mud a finish coat under the popcorn to get a smooth ceiling.
Andy.
ScipioAfricanus is offline   Reply With Quote
Old 02-08-2009, 11:21 PM   #3
Mellison's Avatar
Trade: Home Improvement General Contractor
Good question.
Probably to good a question for a Sunday night after a weekend of fun.
I would think scrape and skim.
"Enjoy Every Sandwich" Warren Zevon
Mellison is offline   Reply With Quote
Old 02-09-2009, 02:01 AM   #4
Organic Painter
Mr. Mike's Avatar
Trade: Painting Contractor
I just completed a 2800 sq. ceiling last week. Took about 120 man hours to wet, scrape, scrape, patch, and apply 2 coats. What a mess though looks great now.
popcorn-ceiling-removal-laminate-ceiling-3-8-p1200141.jpg   popcorn-ceiling-removal-laminate-ceiling-3-8-p1200144.jpg   popcorn-ceiling-removal-laminate-ceiling-3-8-p1200160.jpg
Mr. Mike is offline   Reply With Quote
Old 02-09-2009, 07:55 AM   #5
Trade: Residential Remodeling
While doing a bathroom renovation the HO decided to have us remove the stipple ceiling and go to smooth. Approx. 2000 sf that I turned over to the drywall sub. The HO and I left it up to him to determine the best method.
I'm not sure of his calcs for 3/8" but I know he had about 90 hours to scrape and apply to skim coats so I can only assume it was more cost effective to scrape.
AtlRemodeling is offline   Reply With Quote
Old 02-09-2009, 10:32 AM   #6
Frankawitz's Avatar
Trade: Plastering, Drywall, Painting, Woodworking, Stucco, refinishing woodwork
Mike you need to post the finish photo's, did you float the whole ceiling?
Frankawitz is offline   Reply With Quote
Old 02-09-2009, 11:11 AM   #7
Organic Painter
Mr. Mike's Avatar
Spot patch only.
Old 02-09-2009, 11:11 AM   #8
Sharp Improvements
Norrrrrrrrrrrrm's Avatar
In the past I have sprayed with water, let it soak for 5 minutes and scrape. Generally it only needs one coat of skim if you have skimming skills! No need to waste time and money having to lug drywall around town and buy more mud and tape. Good luck!
Norman Sharp
http://www.sharpimprovements.com
Norrrrrrrrrrrrm is offline   Reply With Quote
Old 02-09-2009, 02:00 PM   #9
Rx8
Trade: Drywall Finisher
Send a message via AIM to Rx8
does this soaking and scraping method work on all textures? i have a dining room in a house im rehabing and it is all roll texture'd and painted; i've been scraping and skimming them in- maybe ill give this wetting first idea a try?
Rx8 is offline   Reply With Quote
Old 02-10-2009, 08:53 AM   #10
Frankawitz's Avatar
Mike nice job looks good
Old 02-10-2009, 02:14 PM   #11
Trade: General Contractor/ Remodeler
Rx8- In my experience the answer to your question depends on how heavy the rolled, sprayed, or other texture was applied, how old it is and how many coats of paint it's been covered with. You could try to scape with pre-spraying. Ceilings I've worked on that were a non popcorn texture took longer to scrape than popcorn, probably because popcorn comes off if you look at it wrong! You will probably be looking at a lot of scimming. You could try the look of a knock down. Hope that helps.
Jonny85 is offline   Reply With Quote
Old 02-11-2009, 08:38 PM   #12
plazaman's Avatar
i only ended up doing 1 ceiling, they let it slide. we presoaked and scrape, came off very easy. It was rolled on plaster ceiling. After scraping, we discover the plaster had cracks allover it, maybe the reason why they rolled the mud on the ceiling to begin with. We ended up meshing the entire ceiling with fiberglass mesh and skim. still in the process, should comeout good.
Old 02-16-2009, 12:07 PM   #13
Fight the New World Order
Trade: General
Thumbs up
Hey Mike,
Great job on the ceiling! but I was wondering, did you use a ladder? if so dude you gotta get a scaffold!! and maybe a larger sprayer! LOL!! If the tools really made the man, MIKE WOULD STILL BE THE MAN!!
simplejack is offline   Reply With Quote
Old 03-04-2009, 07:01 AM   #14
Trade: Drywall
Did you think about using a Porter Cable Drywall Sander for this project? The model number is 7800. I have heard of people using them for popcorn removal.
oruscire is offline   Reply With Quote
Old 03-04-2009, 09:42 AM   #15
Darren@Partners
Trade: Drywall Contractor
All good advice, but no one mentioned the age of the acoustic texture and the possiblity of asbestos content. My sources say that anything prior to '84 is suspect. If its older you should still be okay if you keep it wet (not airborne) and double bag the removed texture. We use a 2 gal. Hudson type sprayer and wall scrapers with extendo poles, never have to get on a bench. Just get enough angle on the handle so not to gouge the **** out of the ceiling.
Darren@Partners is offline   Reply With Quote
Old 03-04-2009, 10:08 AM   #16
Trade: General Contractor, Remodeler
Also no one mentioned that if you use 3/8 shrock on a ceiling, it'll have dips and sags like crazy. 1/2" ceiling board (reinforced)
now i am scared for my future
i've got all ten
smashed a lot of them stupidly before
-john5mt
Forry is offline   Reply With Quote
Old 03-04-2009, 12:15 PM   #17
Organic Painter
Mr. Mike's Avatar
After 1973 Lead not used I think.
Old 03-04-2009, 09:28 PM   #18
Darren@Partners
Lead in the paint. Asbestos in the acoustic texture. Sorry if unclear.
Old 03-06-2009, 11:45 AM   #19
Trade: interior wall changes and bathroom remodeling
I agree with forry, don't use 3/8 drywall over acoustic, because it will way uneven. Far better off to wet and scrape and skim
drycat is offline   Reply With Quote
popcorn ceiling codaman Introductions 16 10-16-2008 11:53 PM
Popcorn ceiling thepainter Remodeling 26 08-20-2008 11:04 PM
Removing popcorn ceiling and wallpaper then retexturing lexter_wolf Drywall 20 05-29-2008 07:46 PM
Popcorn Ceiling cowtown Painting & Finish Work 12 03-30-2006 11:00 PM
Removing popcorn on a high pitch ceiling AAPaint Painting & Finish Work 22 02-02-2006 09:53 AM
