Popcorn Ceiling Bubble Problems?
Old 10-15-2012, 11:25 PM   #1
pro
Builder Butch's Avatar
Trade: builder/remodeler
Rewards Points: 87
I've been doing more insurance work lately requiring me to do ceiling repairs from water damge. Twice I've scraped the popcorn off, quickset the area and sprayed my corn followed by a coat of latex paint. 10 minutes later I get bubbles from the popcorn loosing adhesion where I applied the mud. It once did it without the mud after I scraped down to original drywall. What is the cause and solution?
Builder Butch is offline
Old 10-15-2012, 11:28 PM   #2
pro
Rewards Points: 87
Re: Popcorn Ceiling Bubble Problems?
I'm spraying and not rolling my paint. Does mixing paint with my popcorn help?
Old 10-15-2012, 11:51 PM   #3
r4r&r's Avatar
Trade: Contractor
Yes. If you get the popcorn too wet it looses adhesion just as your experiencing.
r4r&r is offline
Old 10-16-2012, 06:09 AM   #4
Big Shoe's Avatar
Rewards Points: 1,718
The popcorn needs to be 100% dry.
Why are you painting it. Most popcorn here does not get painted.
Expect the Unexpected
Big Shoe is offline
Old 10-16-2012, 08:10 PM   #5
dryrocker27's Avatar
Trade: Drywall Contractor
Rewards Points: 75
We have performed this type of repair work many times. When first started, we had this problem if the Drywall was still damp but did not sag.
After repairs are finished, we prime the repair first, then spray. We also scrape entire ceiling to ensure a uniform look. This has eliminated all texture differences due to previous spray thickness.
Popcorn in our area is fairly light in coverage and will show the board if not primed first or painted last.
Make sure popcorn is dry before painting as mentions in previous posts.
Robert
dryrocker27 is offline
Old 10-16-2012, 08:30 PM   #6
pro
Rewards Points: 87
Thanks for your responses. Dryrocker I think your right, today I oil primed it first, then sprayed texture, used a heat gun to dry it and then painted it without a problem. The other time it happened I repaired it 3 failed times and primed it the 4th before I got it to work. I'm thinking priming and drying it before paint is the key, but its tough to do all in one trip without a heat gun. I've always built new houses so I never experienced this before ad I just thought the other job was a fluke since It has been working perfectly on my previous jobs.
Thanks guys.
Old 10-17-2012, 07:45 PM   #7
icerock drywall's Avatar
Trade: drywaller
Rewards Points: 930
remove that crap
popcorn ceiling bubble problems?-1015121348b.jpg   popcorn ceiling bubble problems?-1015121347.jpg
dont work hard...work smart
icerock drywall is offline
Crown molding on concrete ceiling CadetC Finish Carpentry 13 09-15-2012 10:14 PM
popcorn ceiling removal/painting artinall Painting & Finish Work 14 09-07-2010 02:38 AM
popcorn ceiling codaman Introductions 16 10-17-2008 12:53 AM
Popcorn Ceiling lunaassoc Painting & Finish Work 4 06-26-2006 10:31 PM
Popcorn Ceiling cowtown Painting & Finish Work 12 03-30-2006 11:00 PM
