Plaster Washers
Old 12-15-2008, 10:55 PM   #1
boman47k's Avatar
Plaster Washers
Do any of you find these at the local Lowe's or HD? Ace?
boman47k is offline
Old 12-15-2008, 11:14 PM   #2
Re: Plaster Washers
Drywall supply, hardware stores,
McFeeley's has 'em too.
neolitic is offline
Old 12-16-2008, 04:30 AM   #3
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Send a message via Yahoo to chris n
Re: Plaster Washers
http://www.mcfeelys.com/category.asp...ers|1426474261
chris n is offline
Old 12-16-2008, 07:26 AM   #4
Frankawitz's Avatar
Re: Plaster Washers
Hey those are fine for foam. If I use washers I use 2 1/2" flat washers and a 3" deck screw. those thing aren't long enough cause you will use hundreds were if you use the flat washers 2 1/2" you can spread them further apart. I had a job a few years back the ceiling had dropped 4" off the joists. Good luck
www.frankawitz.net
Frankawitz is offline
Old 12-16-2008, 08:29 AM   #5
boman47k's Avatar
Re: Plaster Washers
I may not need them. The job I am thinking about there is some plaster and dw damage caused by a leak. This is a case,imo, that prob needs r&r due to the possibility and or likelyhood of mold between the plaster and the lathe.
boman47k is offline
Old 12-17-2008, 12:42 PM   #6
boman47k's Avatar
Re: Plaster Washers
Called several places here yesterday and could find no one that stocks the washers. Not enough demand for them. I guess most repairs are made with dw and mud. Seems that might not be acceptable in the historic district, but maybe it is.
I might call an industrial supply house for the heck of it. We also have a fastener manufacturer here that just might produce them. I know they do screws, bolts, etc..
Might be worth learning to repair paster with plaster.
boman47k is offline
Old 12-17-2008, 05:20 PM   #7
gallerytungsten's Avatar
Trade: Design
Re: Plaster Washers
I've gotten a bunch from here:
charlesstsupply . com/plaster_washers
Note: it's a good idea to buy stainless screws for this!
(wack 15 post rule prevented posting a clickable link...)
gallerytungsten is offline
Old 12-17-2008, 06:31 PM   #8
painterman's Avatar
Trade: Historic Restorations
Re: Plaster Washers
Lee Valley stocks packages of 100?
painterman is offline
Old 12-17-2008, 08:30 PM   #9
Hawaii Handyman Remoleing
Aaron111's Avatar
Trade: Honolulu, Hi Handyman Remodeler 510-868-8807
Send a message via MSN to Aaron111 Send a message via Yahoo to Aaron111
Re: Plaster Washers
sorry never herd of it
Aaron111 is offline
Old 12-18-2008, 07:44 AM   #10
painterman's Avatar
Re: Plaster Washers
www.leevalleytools.com
Old 12-27-2008, 12:47 PM   #11
plasterguy's Avatar
Trade: Historic Plaster Preservation
Re: Plaster Washers
There is a new method for repairing plaster walls and ceilings, using a special adhesive rather than washer, to effectively "glue" the plaster back in place. It's been featured by Tom Silva on "This Old House" and makes plaster repair twice as fast and much easier.
You can check out the review on this old house here:
thisoldhouse.com/toh/article/0,,1628100,00.html
The adhesive can be found here:
plastermagic.com
plasterguy is offline
Old 12-27-2008, 02:44 PM   #12
boman47k's Avatar
Re: Plaster Washers
plastermagic.com
Have you used this system? The reviews on that article were not very encouraging.
boman47k is offline
Plaster applied to interior of interior wall problems CMU General Discussion 1 10-14-2008 10:37 AM
Plaster Repair Al Taper Drywall 8 10-13-2008 08:34 PM
Painting new plaster ProWallGuy Painting & Finish Work 18 11-27-2007 11:59 PM
Old plaster that won't hold paint hbiss Painting & Finish Work 14 07-28-2007 08:50 AM
Plaster Removal Mulecreek Drywall 8 01-16-2007 10:13 AM
