Trade: hvac contractor
Plaster Help!!!
Hello I'm a heating and air contractor in alabama, I am installing a duct sysyem in the attic of a 70 year old house with plaster celings. I have done this before , but I am looking to a more productive way than I curantly e. I have been using a sawzaw (recipocating) with "Plaster" blades. They work well but sure takes a number of them. I have quite a few holes going in to this job. Is there another way?
Re: Plaster Help!!!
Grinder, diamond blade----shopvac and helper
Trade: Home repairs,drywall,trim.
Re: Plaster Help!!!
Ditto,watch your fingers! Wear heavy duty gloves.
Re: Plaster Help!!!
I always use my plaster axe, If you take and chop a line with the axe then pull the plaster off the ceiling. is there wood lath or rock lath? if theres wood you don't need to hit it that hard, now if theres rock lath you'll need to smack it hard then once you find the ceiling joists just cut along it. the only saw I have ever use was a drywall hand saw, works well on rock lath plaster but not on wood lath plaster. Good luck
Re: Plaster Help!!!
Will the grinder with a diamond blade give a smooth cut?
Trade: acoustical dry wall
Re: Plaster Help!!!
you have to remove the plaster out of the way. like frankowitz SASE this will save a Lott of blades, i always beat a line before sawing
Trade: Drylining
Re: Plaster Help!!!
Try one of these. They are really accurate.
http://www.feinmultimaster.co.uk/fein_multimaster.htm You should be able to get them in the US |
Doofenshmirtz Evil Inc.
Re: Plaster Help!!!
Rotozip and a vacuum with a plaster bit.
in texas with framing and cornish people will do it for 3.00 a foot. What do yall think about that? Just laber |
| Drywall over plaster ceiling? | RandyB1986 | Drywall | 34 | 11-29-2011 05:09 PM |
| Old brick & mortar pond with plaster coating, need help | kjac3585 | Masonry | 2 | 08-12-2009 07:02 PM |
| Question about patching plaster | Dorman Painting | Painting & Finish Work | 4 | 02-09-2009 10:49 PM |
| Plaster applied to interior of interior wall problems | CMU | General Discussion | 1 | 10-14-2008 10:37 AM |
| Old plaster that won't hold paint | hbiss | Painting & Finish Work | 14 | 07-28-2007 08:50 AM |
