Plaster Estimate And Other Contractors
Old 10-22-2009, 08:25 AM   #81
Frankawitz's Avatar
Re: Plaster Estimate And Other Contractors
Resta,
What is a armature? I don't understand I got the mould off the crown and brought it home, you can see in the pictures what I ended up with after I trimmed off the edges.
Plaster Estimate and other contractors-1791-burns-indian-village-detroit-mi-333.jpg   Plaster Estimate and other contractors-1791-burns-indian-village-detroit-mi-337.jpg   Plaster Estimate and other contractors-1791-burns-indian-village-detroit-mi-340.jpg
Frankawitz is offline
Old 10-23-2009, 09:34 AM   #82
Resta's Avatar
Trade: Ornamental Plasterer/Restorer
Frankawitz, generally for plastic moulds on all perimeter I use fiber chunks in the paste to keep borders from every side stronger and not flexible. And use "[" channels to keep mould in proper position vertical and horizontal. In your photos looks like endways are saggy. I'll make armature in that way: two-three horizontal and four vertical beams.
Resta is offline
Old 10-23-2009, 10:22 PM   #83
Frankawitz's Avatar
Resta,
Your termanology is different then what I use, I build channels for the mold to set in. then I can pour my moulding plaster over the mould.
Plaster Estimate and other contractors-1791-burns-indian-village-detroit-mi-346.jpg   Plaster Estimate and other contractors-1791-burns-indian-village-detroit-mi-347.jpg   Plaster Estimate and other contractors-1791-burns-indian-village-detroit-mi-348.jpg
Old 10-23-2009, 10:55 PM   #84
Resta's Avatar
It is as broad as it is long. I think that is not the question about terminology or little differences in technology. You have good results, client is happy, you have $$ family to feed.
Resta is offline
Old 10-29-2009, 08:52 AM   #85
rogerhattman's Avatar
Trade: plaster/stucco
Frank,
Everything looks great.
Do you cast the whole cornice/crown (as it appears from your mould), or do you run the plain portions and add the enrichments later?
rogerhattman is offline
Old 10-30-2009, 07:14 AM   #86
Frankawitz's Avatar
Roger I was trying to cast the whole piece, but after two trys I am thinking of doing just the cornice then run the crown in place, the thing that sucks is these people only want me working Saturday and Sundays or after 3:30pm Mon thru Fri. It is not the best working conditions. So now I am doing some painting of a couple bedrooms at another customers house. I tried to set up the forms to cast the piece but I may have to go back down there and apply more rubber to just the cornice part of the moulding. this is a PAIN.
Old 10-30-2009, 09:55 AM   #87
I believe ordinarily it is done as you just described. At least the casting will be a a little easier to handle.
I can see how your forced work schedule would be a hindrance.
Old 10-30-2009, 05:33 PM   #88
Resta's Avatar
Frank, if you have some discomfort casting like this what I see in the photo, try another way. Stick a molding on the table in position like letter V upside-down, that rubber edges stay in that same horizontal level on either side. Soak half bucket water with plaster, pour off upper half to another bucket. Mix first bucket and apply first splash coat. Cut proper size of burlap, mix second bucket, soak burlap with plaster and put on, trippingly press down. Take back side template and gently run to have whole piece same thickness. When you have all footage done, you’ll install them fast ant easy.
Resta is offline
Old 10-30-2009, 05:39 PM   #89
Resta's Avatar
I think to cast and put these enrichments on plaster...and clean everything ...takes more time, but willco traditional way.
Resta is offline
Old 10-30-2009, 08:07 PM   #90
Frankawitz's Avatar
Roger, Your right that is how they did it they ran the crown and cast the cornice, then laid it in place, when I took out the water damaged section I could see it was two pieces. Resta, I hear what your saying and I will try that and see if I can get it to work. Thanks for the information I appreciate it. I'll let you guys know how it worked out.
Old 11-02-2009, 07:29 PM   #91
Frankawitz's Avatar
Well Resta, I did like you said and I managed to get a good cornice moulding.
Now I am going to wait for it to cure then I am going to prime and then make a new rubber mould of the cornice, But here's some pictures of what I have.
Plaster Estimate and other contractors-1791-burns-indian-village-detroit-mi-352.jpg   Plaster Estimate and other contractors-1791-burns-indian-village-detroit-mi-353.jpg   Plaster Estimate and other contractors-1791-burns-indian-village-detroit-mi-354.jpg
Old 11-10-2009, 07:18 AM   #92
Frankawitz's Avatar
Well I tried to reform the Cornice and pour another, I keep making the edges to thick.
Plaster Estimate and other contractors-1791-burns-indian-village-detroit-mi-355.jpg   Plaster Estimate and other contractors-1791-burns-indian-village-detroit-mi-356.jpg   Plaster Estimate and other contractors-1791-burns-indian-village-detroit-mi-357.jpg
Old 11-10-2009, 11:24 PM   #93
Resta's Avatar
Frank, make back side template to keep proper thicknes and run back side in that same way like you running moldings on the walls. On other hand you can shave back side of edges with the rasp/shaver/scraper.
Resta is offline
Old 11-14-2009, 07:42 AM   #94
Frankawitz's Avatar
Resta, Sounds good, I will try that, Last night I had to go down and take my bakker down and pull the drops out of the house, They are having Party's with the holidays coming so now I am under the gun, which I knew was coming, yet these people have not made it easy to do this job, so in the end I really don't care how long it takes me at this point, when I start working for these people it was August and they went on vacation and then when school started I was told I could only work after 3:30pm and on Saturdays and Sundays and now she wants me to get it done right away yeah Whatever I have already lost money so why should I care if they are having Party's over the holidays
Old 12-05-2009, 07:59 AM   #95
Frankawitz's Avatar
Well as time goes on I have only worked on these cornice mouldings a little bit casue with other jobs coming in I don't have much time. I made another rubber mould so I could get just the cornice part, so I believe I got the right mould so I knocked out two pieces last night. only have 8 more pieces to go
Old 12-09-2009, 04:36 AM   #96
Frankawitz's Avatar
Ok well this is getting done at a slow pace, I hope to have the rest of the pieces done this week.
Plaster Estimate and other contractors-burns-indian-village-detroit-mi-004.jpg   Plaster Estimate and other contractors-burns-indian-village-detroit-mi-013.jpg   Plaster Estimate and other contractors-burns-indian-village-detroit-mi-014.jpg
Old 12-09-2009, 04:44 AM   #97
Frankawitz's Avatar
With this new mould I just dump the plaster over the cornice and work it in
seems to work about the best, cause these pieces are about 3/8" thick
Plaster Estimate and other contractors-burns-indian-village-detroit-mi-012.jpg
Old 12-10-2009, 07:49 PM   #98
Frankawitz's Avatar
I got the cornice mouldings going today and I knocked out 6 pieces, I also came up with a better technic to trowel the backs, the last picture of a wall piece.
Plaster Estimate and other contractors-burns-indian-village-detroit-mi-015.jpg   Plaster Estimate and other contractors-burns-indian-village-detroit-mi-016.jpg   Plaster Estimate and other contractors-burns-indian-village-detroit-mi-017.jpg
Old 12-10-2009, 09:37 PM   #99
Resta's Avatar
Resta is offline
Old 12-18-2009, 06:34 PM   #100
Frankawitz's Avatar
Well I got 10 pieces made up that what this stack is and now I am working on making the knife for the top part of the crown.
The middle picture is of a wall plaque I poured, the bottom picture is of the two pieces of the crown I made.
Plaster Estimate and other contractors-burns-indian-village-detroit-mi-022.jpg   Plaster Estimate and other contractors-burns-indian-village-detroit-mi-023.jpg   Plaster Estimate and other contractors-burns-indian-village-detroit-mi-028.jpg
