Trade: home improvement
Patch Blister
I recently repaired a ceiling with dryall and fiberglass tape with hot mud. after finishing the patch i primed the area and some blisters appeared where the mud was over the old painted surface. the mud actually came off. i've never had this problem before. any insights?
#2 | |
Trade: drywall contractor
Re: Patch BlisterQuote:
I have started priming the area around to make sure the mud sticks to all of the surface. Prime plenty wide. Best to use an oil base or Zinser 123. Then prime again over the mud. Durabond is known for doing that. All fast set is. Regular mud won't as much, but still safer to prime first. |
Re: Patch Blister
Thanks for the reply. Now how do I fix the problem without starting over from scratch?????
Re: Patch Blister |
Re: Patch Blister
Actually easy sand 20 min is what I was using. Do I need to prime the area before applying new mud?
#6 | |
It is surprising the first time let loose. Was there a moisture problem that caused the need for the patch? Was it over plaster or drywall? You may have already said in earlier post. Trying to figure it out. |
Re: Patch Blister
The patch was to repair ceiling where plumber cut holes to find leak from upstairs bathroom. no serious moisture problem. all seems dry. original ceiling was drywall with plaster skimcoat. painted with satin finish paint. I'm thinking that there might have been grease or dirt on surface that was not detected as this was in kitchen area. I will remove any loose spots and sand into painted areas to get better adhesion. thanks for your help
#8 | |
| Stucco patch, how much to do EIFS patches? | sniperninjafox | Painting & Finish Work | 7 | 09-26-2007 08:41 PM |
| Plaster hole patch | ODDBALLS | Drywall | 8 | 09-19-2007 10:29 PM |
| Patch is showing up (question) | Txbassboy | Drywall | 14 | 01-13-2007 10:29 AM |
| Stucco patch | CEM2 | General Discussion | 5 | 03-23-2006 04:24 PM |
