Paper Or Fiberglass
Old 02-22-2006, 09:42 PM   #1
daveeturner's Avatar
Trade: Audio/Video/Automation
Paper Or Fiberglass
What kind of tape is best to be used in drywall installations... paper or tape? I have recently heard paper because of the ease of mudding it, but it would seem that fiberglass would be more durable. What do you guys think?
daveeturner is offline
Old 02-22-2006, 10:02 PM   #2
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Re: Paper Or Fiberglass
I'd use paper for seams, but I do use fiberglass mesh for repairs.
ProWallGuy is offline
Old 02-22-2006, 10:33 PM   #3
drywall contractor
damudman's Avatar
Trade: drywall
Paper I think is stronger. Fiberglass for repairs.
Mesh should be used with hot mud.
damudman is offline
Old 02-22-2006, 11:17 PM   #4
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
I use mesh for everything but the corners where I just use caulk.
Just kidding, paper in the corners but mesh everywhere else, even the ceiling. I love the self stick of the mesh and even though some guys don't like for ceilings I have no problems with it.
Mike Finley is offline
Old 02-23-2006, 09:41 AM   #5
SAGE
sage's Avatar
Trade: Remodeler and Finish Carpenter
LOL Me too
No seriously though. The handyman on my last job used caulk for the corners of small closet he built at the end of a hall. Basically put up a small wall with bifolds to close off some dead space. I was laughing and would never do it but I gotta tell ya it didn't look that bad, surprisingly.
But this is the same guy that used joint compound to fix up his F'd up crown joints.
-Lead from the front, or dont lead at all-
sage is offline
Old 02-23-2006, 04:42 PM   #6
BlkBart54's Avatar
Trade: Drywall and Painting contractor
Paper tape is probably the safest bet for everything for you. Mesh can only be guaranteed if coated with set fast mud. Also the mesh needs to be buried ,thus you can only use on the flats. I also use mesh to tpe down the edges of my metal cornerbead. One its coated its almost impossible to crack. Also use mesh for small repair and detail as its so quick. Mesh can also be used it angles to reinforce gaps. Especially on ceiling side as after meshing problem and prefilling, it will only keep enough to fill it and won,t sag due to gravity. When using the hot mud (set-fast 90) on the flats be careful to wipe it tighter then usual or you,ll overfill the flat.
BlkBart54 is offline
Old 02-23-2006, 11:15 PM   #7
theworx's Avatar
Why not just use tape on corner beads. By the time you crimp on or screw the metal bead on and then add the mesh tape I could have set the corner and done my first fill coat?
theworx is offline
Old 02-23-2006, 11:39 PM   #8
theworx's Avatar
If it's a small patch job, mesh is fine. If you are taping a larger job gotta use paper. Many guys on the forum have said they use mesh but, I guess a lot of it has to do with our climate. Up here in Canada a building can move as much as two inches (up or down) with seasonal changes. And I've found that the mesh tape doesn't hold up as well (I've used it). Paper tape installed properly is much more durable.
I boarded and taped my brothers cottage last summer. We went out there a week ago after it heaved from the freezing and all my joints were intact but the drywall had cracked in a few places. I would have thought that my seams would have cracked but they didn't. I used paper and that's a pretty good example of how strong a paper taped joint can be...
theworx is offline
Ceramic tile on top of fiberglass pan? rayn41c Ceramic & Stone Tile 17 05-23-2007 06:59 AM
Fiberglass just not popular in every area.... ruskent Pool Construction & Enclosures 14 04-16-2007 11:05 AM
Type of Paper Under Hardwood CharlieDaw Flooring 2 04-12-2007 10:43 PM
Paper Adhesive tape. jstrand23 Drywall 1 03-07-2007 06:02 PM
commercial wall paper removal rservices Wallpaper 1 06-28-2006 09:58 PM
