New Texture Over Paint?
Old 03-13-2009, 06:59 PM   #1
SK Builders's Avatar
Trade: Remodeling contractor
Hi guys, I'm working on an estimate and the house needs re-textured smooth. This is a 1 year old house, 2500sf, ten ft. ceilings...can this be done and what is the proper procedure? I am not price shopping, just want to know what to expect the contractors to do...you know how it is, some will cut corners, but I don't know the particulars...any help is appreciated, thanks, Scott
Scott-master of my domain...
SK Builders is offline
Old 03-14-2009, 06:16 PM   #2
Happy Taper
Mudstar's Avatar
Trade: Mud Wrestler
Re: New Texture Over Paint?
This is not like repairing a car. Its a skill and art that everyone does a little different. No one persons work looks the same, its the end result your looking for is what matters.
If you look to deep into it, you more then likely won't be satisfied at the end. Find someones work you like and stick with them.
Nothing personal but this is not a contest and not everyone is the same so with that said you should rethink your question.
Mudstar is offline
Old 03-14-2009, 07:09 PM   #3
Butt Expert
Brocktologist's Avatar
Trade: Drywall
What was the question again?
Brocktologist is offline
Old 03-14-2009, 08:58 PM   #4
OK I will rephrase the question...how do you apply texture over paint and make it stay? This house was screwed up the first time and I want to make sure the prep( if there is any) is done and done correctly...
Old 03-14-2009, 09:19 PM   #5
Home Depot aisle walker
willworkforbeer's Avatar
Trade: home remodeling
Just guessing I'd say either rub de-glosser on the whole thing (if its anything other than flat paint) or prime it first.
willworkforbeer is offline
Old 03-15-2009, 08:44 AM   #6
Frankawitz's Avatar
Scott
now you said retexture smooth, Do you have texture now and your wanting to smooth it out? with everything being painted, yeah you can use de glosser or use TSP spray on wipe down to break the painted surfaces, I would base coat with Durabond 90 then pull topping and sand it out.
www.frankawitz.net
Frankawitz is offline
The Following User Says Thank You to Frankawitz For This Useful Post:
SK Builders (03-15-2009)
Old 03-15-2009, 06:43 PM   #7
Butt Expert
Trade: Drywall
Originally Posted by Frankawitz View Post
Scott
www.frankawitz.net
I guess that's what he's axen.
TSP, durabond and top coat would be a great start. What a PIA!
Old 03-15-2009, 06:51 PM   #8
yeah the house has a mostly smooth texture, but it is pretty bad in some areas. Was supposed to be a hand trowel finish to start, but that wasn't done right, so they tried to make it smooth and it just didn't work out very well...course the builder kept telling the homeowners he would take care of it....now it needs to be fixed along with a bunch of other stuff. Thanks for the replies guys....Scott
Old 03-15-2009, 09:32 PM   #9
Butt Expert
Trade: Drywall
So he wants a price on making it smooth? I suppose all the trim is up and folks are living there too?
Old 03-15-2009, 09:34 PM   #10
yup, you got it, but they are willing to move out for a month...
Old 03-15-2009, 09:37 PM   #11
Tim0282's Avatar
Trade: drywall contractor
I think it is "mostly" smooth and he wants it textured. I think that is the direction, anyway.
Tim0282 is offline
Old 03-15-2009, 09:40 PM   #12
It is mostly smooth and he wants it all smooth. I just figure to re-do the whole house just because of the inconsistencies all over...be kind of hard to do it here and there and do a thorough job. Does that make sense?
Old 03-15-2009, 09:40 PM   #13
Tim0282's Avatar
I was wrong. We want it the real smooth texture, not the mostly smooth texture.
Skim all of it real tight with mud and sand a little.
Tim0282 is offline
Old 03-15-2009, 09:42 PM   #14
Tim0282's Avatar
Prime with a good quality primer once the roughness is skimmed out, then paint at least two coats of finish. Should be up to snuff...
Tim0282 is offline
Old 03-15-2009, 09:43 PM   #15
That sounds about right, just not sure of how it's done over existing paint...just want it done right...I'm not a drywall guy so I don't know the sequence..................sorry, you're too fast for my typing!!! Thanks Tim...can this be done over the existing paint??
Old 03-16-2009, 06:36 AM   #16
Frankawitz's Avatar
Scott,
The paint surface has to be broken, so the mud will bond. otherwise when your painters put the paint on the mud can bubble. so just make sure
www.frankawitz.net
paint flaking from the ceiling...cause/solution?? lornmastro Painting & Finish Work 26 03-06-2009 03:14 PM
here's a painting price list...... Jer44 General Discussion 9 02-17-2009 08:30 AM
Green Paint Division toddcla2002 Painting & Finish Work 17 01-24-2008 03:22 AM
Wait to paint ceiling texture: How long?? steve-in-kville Painting & Finish Work 7 06-15-2007 08:39 PM
