New Texture Over Old
Old 01-27-2012, 06:03 PM   #1
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 1,916
Commercial client is in a leased space. They don't want to spend a ton of money, just do sort-of do a face-lift. They might only be there another couple years. Anyway, the drywall is old, been painted a couple (few) times, paper tape is coming out of the corners due to earthquakes, a few dents and dings and old, patched holes. I want to redo the tape in the corners and skimcoat and texture the whole thing. Should still be alot cheaper than a complete tear-out. So I'm wondering if there is something I should use to ensure a good bond between the paint and the new topping compound, kind of like weld-crete for concrete. Will an oil-based primer work? Thanks in advance to all the 'rockers!
I have an Edifice Complex.
Old 01-27-2012, 06:07 PM   #2
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Re: New Texture Over Old
I would apply a bonding primer to the existing ceiling then mix in a gallon of same primer into the topping.
ohiohomedoctor is offline
Old 01-27-2012, 06:23 PM   #3
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Depending on the existing texture it might be cheaper and faster to hang 1/4" drywall over everything then tape and texture.
There would be positives and negatives to skimming versus, depending on your definition of "facelift".
CrpntrFrk is offline
Old 01-27-2012, 08:02 PM   #4
Drywall & Tape
PrecisionTaping's Avatar
Trade: Drywall, Taping & Stucco
Rewards Points: 250
I agree.
Also, I wouldnt use an oil based primer.
Acrylic. Unless its already an oil.
PrecisionTaping is offline
Old 01-28-2012, 01:18 AM   #5
Trade: Builder/GC
I had thought about covering with 1/4" like I've done on other jobs, but this one has alot of windows, outlets, and what-not. Since the trim is all painted, I could just butt and caulk, but there are other issues with overlay, such as where it would end. It's kind of a complicated building. Besides, the 1/4" costs more here than 1/2". I thought if I could skip the hanging part, I could keep the cost down and get the work.
I agree.
It's just latex paint. So you're saying a water-based primer might give sufficient bond?
Old 01-28-2012, 05:18 AM   #6
Big Shoe's Avatar
Rewards Points: 1,728
1/4'' is not the ''silver bullet'' to poor quality walls in most cases. It opens up a whole nother can of worms.
I clean up all loose paper, bad areas, powersand,prime with oil (cover stain) and repair all areas needed.
Have yet to try Gaurdz(instead of oil) but will on the next job like this now that I finally know where to get it here.
You may find the walls to be in better shape than you thought after sadning and priming.
If I had a nickel for every time someone said cover it with 1/4''
Not knocking it. Just not my cup of tea.
Big Shoe is offline
Old 01-28-2012, 09:11 AM   #7
CrpntrFrk's Avatar
I was picturing a huge commercial space and the OP mentioned "tear out" so I suggested 1/4" thing. I personally don't like the 1/4" thing but if the drywall that is currently up is in horrible condition then I figured that might be cheaper.
The last skim over we just did not more than a month ago was a nightmare. About a 20'x20' room. Walls had paper and the ceiling was the grossest spray texture I had ever seen. 3 skim coats just to make it disappear after scrapping!
Good luck.
The Following User Says Thank You to CrpntrFrk For This Useful Post:
Big Shoe (01-29-2012)
Old 01-28-2012, 09:18 AM   #8
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,115
+1 for the guardz or I've even used a an exterior multi-purpose clear sealer on it. For really nasty stuff I would use an oil primer. Never been a fan of the "just go over it with 1/4" theory either.
Skimming goes pretty fast. Especially if your going to be applying texture over it.
Sir Mixalot is offline
The Following User Says Thank You to Sir Mixalot For This Useful Post:
Old 01-28-2012, 10:09 AM   #9
Trade: Builder/GC
Thanks for all the help, guys. I'm gonna check into the Guardz.
Old 01-29-2012, 03:39 AM   #10
Big Shoe's Avatar
Good luck.
Frank, I know where you're coming from.
I have a job scheduled in three weeks to remove beadboard. It's 5' high in a bedroom on second floor. The other room I did there last year had the same ting. I removed the drywall and replaced it. (Judgement Call) Hope they did'nt use as much glue in this room.
I always would rather skim than replace/double up. I'll try to get some pics on that one.
Big Shoe is offline
The Following User Says Thank You to Big Shoe For This Useful Post:
Sir Mixalot (01-29-2012)
Old 01-29-2012, 12:26 PM   #11
Drywall & Tape
Rewards Points: 250
Ya I guess it depends how bad the existing ceiling is.
Its hard to judge, I know I said just regular acrylic primer is fine, but if its excessive damage and you're thinking of re-skimming the whole ceiling you might want to try something like plaster-weld.
http://www.larsenproducts.com/plasterweld.php
Old 01-31-2012, 05:39 PM   #12
Trade: Builder/GC
Thanks for the link on the plaster-weld. I think either of those (plaster-weld or guardz) will work. The drywall is good shape, just a few places where there were water leaks years ago, and the texture has peeled off. Also the tape in the corners is coming off due to "seismic activity". The restrooms have several not-so-great patch jobs, and there must be a dozen coats of paint over the years. Hence my desire just to skim coat everything. I always find it difficult to match that "rounded texture" look of a wall with multiple coats of paint.
Old 01-31-2012, 05:55 PM   #13
Drywall & Tape
Rewards Points: 250
Well said, I agree.
Popcorn Texture over Concrete AM1965 Drywall 14 04-15-2010 10:51 AM
Ceiling texture fun!! EricTheHandyman Drywall 2 04-01-2009 09:14 PM
Snow texture, popcorn texture... AARC Drywall Drywall 5 10-30-2008 01:30 AM
Pock marks in Orange Peel texture MCComplete Drywall 4 01-14-2008 10:09 AM
Drywall repair - texture matching help build4Him Drywall 2 05-29-2006 08:50 AM
