Need Advice On Using A Texture Gun
Old 12-11-2005, 07:17 PM   #1
cumminsdiesel's Avatar
Trade: general contractor
I've been thinking about buying a texture gun to texture ceilings but I have never used one before. I'm just wondering how they work. Do they actually spray a texture or just spray the mud on and then you stomp it? Also how messy are they compared to just rolling the mud on?
cumminsdiesel is offline
Old 12-11-2005, 08:03 PM   #2
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: Need Advice On Using A Texture Gun
Set-up and prep takes the longest amount of time, actual spraying and working the surface depending on what you are trying to do takes very little time at all. It's going to be way, way, WAY! faster than rolling and much more versitile. You'll have to spend some time doing some test boards to see the different combinations, because you have multiple variables, nozzle size, PSI, mix consistancy that will all effect the results, not to mention the differences in what the texture will do when it hits clean sheet rock and the mudded areas.
Mike Finley is offline
Old 12-11-2005, 08:17 PM   #3
thanks for the reply.... so when you spray this on it will already be textured or do you have use a texture brush after you spray it.
Old 12-11-2005, 08:59 PM   #4
Chief Toilet Mover
It depends on what texture you want. Eggshell comes out of the gun and you are done, knock down your need to well... knock it down with a knock down knife.
Old 12-11-2005, 09:10 PM   #5
Ok thats what I needed to know, I plan on doing a knockdown texture. I've just never used a gun before and didn't understand how it could spray a pattern but if it works it will make my life a heck of a lot easier. I have a Dewalt double tank emglo compressor I use for finish work and roofing will this be enough to power one of these or do I need to use a larger shop compressor?
Old 12-11-2005, 10:25 PM   #6
slowsol's Avatar
Trade: General Contracting
your dewalt tank will be fine. like he said above though, you will have to practive on some board first to figure out your air pressure.
slowsol is offline
Old 12-12-2005, 12:27 AM   #7
Chief Toilet Mover
I use a Porter Cable pancake compressor set at about 40 PSI, Sheetrock brand wall & ceiling texture dry mix, a Spraying Mantis spray gun. I mix the texture up using a mixing drill and paddle to a pan cake batter consistancy, making sure to mix the hell out of it. Any chunks will clog your gun and even worse small ones will show up all over the wall texture.
I tape everything off just like spraying a car. I shoot all the surfaces and go clean up the gun, compressor hose and anything else. Come back and check to see if the texture has set up a bit. When it's ready I use a wide plastic knock down knife and start in the first place I sprayed and work to the last place I sprayed.
I'm not the best at this so I often come back with a sanding pole after it all drys and go over it all really quickly and that usually makes it look great.
This is the knife I use for knock down.
A lot of other people probably like the squeegy looking knock down knife.
Keep in mind I only do remodeling so this is what works for me. Doing it on an entire house or on new construction would require doing it differently. I'm sure I have a lot to learn in regard to texturing and have a long way to go with it. It seems to be a real art to doing it well. I have hired professional texture finishers for jobs where texture matching was crucial.
Old 12-12-2005, 10:32 PM   #8
Priced In
JustaFramer's Avatar
Trade: Exiled For Life
For doing ceilings make sure you get the 45 pipe if the gun doesn't come with it. I have only sprayed orange peel with a gun. Not a hard texture style to match to existing. Even out of a can.
JustaFramer is offline
Drywall repair - texture matching help build4Him Drywall 2 05-29-2006 09:50 AM
Texture Sprayers Tenspound Drywall 3 01-27-2006 01:24 AM
Priming Drwall and Texture remodelnut Painting & Finish Work 25 01-12-2006 08:09 AM
Advice on estimating skip trowel texture saucedo80 General Discussion 4 09-09-2005 07:15 PM
Advice on estimating skip trowel texture saucedo80 Drywall 2 09-08-2005 09:55 AM
