Trade: Estate Management
Mudding A Wall Liner
Have a customer who wanted wall liner hung over top drywall. (there was wall paper and they did a piss poor job of removing it.)
I've never hung wall liner before so I did a little research, talked to a couple local guys and then hung it up. I let it dry then mudded the seams. Half the seams held and the other half bubbled and the mud cracked. My customer has NOT seem this mess yet. Should I seal the wall liner with primer then go back and mud it or lift the seams and glue it down first? I do NOT want to tear down but if I have to lift every seam and glue it down I will. I just don't want to waste my time and make a bigger mess of it. This customer has given me a lot of work and I want to make this right. Any ideas? |
Butt Expert
Trade: Drywall
Re: Mudding A Wall Liner
I'm not familiar with the wall liner you used but do you think a product like "Guards" will penetrate through it and lay it back down?
I've used it on several job's and it worked well. |
| The Following User Says Thank You to Brocktologist For This Useful Post: | yoderb (11-01-2009) |
That is a very useful suggestion. I'll give it a go and post how it went.
Thank you. |
Butt Expert
Trade: Drywall
How did you get the job fixed?
Did the Guardz soak through the wall liner and into the paper? |
Hey,
Finished the final coat of paint the other day and everything held in place. My client is very happy. The extra adhesive did the trick. |
I would NEVER suggest to anyone to mud wall liner unless it was already sealed with at least one coat of paint that has cured.
I suppose there is a trick to it, but new wall liner is very moister sensitive, the seams can not be over lapped or butted right up against each other; they need to have a bit of a gap between them. |
| Railroad Tie Retaining Wall Question | SDFConstruction | Landscaping | 17 | 03-23-2010 08:42 AM |
| Removing studs from a load bearing wall. | Russ25nys | Framing | 36 | 06-13-2009 09:52 PM |
| Wall papered brick wall repaint | sparehair | Painting & Finish Work | 1 | 12-28-2008 08:01 PM |
| CMU wall repair | mcgyverdc | Masonry | 6 | 12-04-2008 04:48 PM |
| Plaster applied to interior of interior wall problems | CMU | General Discussion | 1 | 10-14-2008 10:37 AM |
