Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Drywall
Old 10-08-2009, 11:52 AM   #21
Rockhound's Avatar
Trade: Drywall Hanger
Send a message via Yahoo to Rockhound
Alot of greenboard is now mold AND moisture resistant. The core and the paper are both treated so screws and nails dont void the treament.
Shue Drywall...We helped our cousin hang his basement once
Rockhound is offline   Reply With Quote
Old 10-08-2009, 02:57 PM   #22
Pompass Ass
It is called XP and it is Purple (Barney Board), instead of green.
bwalley is offline   Reply With Quote
Old 10-08-2009, 02:58 PM   #23
Pompass Ass
Originally Posted by tuffplay View Post
I would use a good paint or sealer instead of purchasing mold resistant sheet rock which can be expensive, not to mention once it is attached via screws or nails, the mold resistant surface is no longer covering the entire sheet, thus it is still suseptible to mold.
You should quit smoking crack, that **** is bad for you.
The Following User Says Thank You to bwalley For This Useful Post:
angus242 (10-08-2009)
Old 10-12-2009, 01:32 PM   #24
Trade: builder
Borate has been used for decades in Europe to stop dry rot and termites and even in the USA it has been around for at least 10 years. The glycol is the carrier to help it penetrate the wood.
Seems like some people in construction have 20 years of experience that really translates into repeating what they learned their first year for the next 19. An old saying about insanity is repeating the same process and expecting a different outcome. When I come across a problem I try to do more than just replace what was done the first time around 30 years ago by a spec home builder only concerned with making it through the warranty period.
Phillip Marsh is offline   Reply With Quote
Old 10-12-2009, 02:29 PM   #25
Rockhound's Avatar
Except for the green board thats green instead of being purple rather than green. Or blue. Or gray.Or brown. There are several manufacturers making Mold/Moisture resistant rock.Each one makes it a different color. People tend to call any moisture resistant board "green" despite its color. But some is actually green. The names vary which causes some confusion at times. Then you have the Fire/Moisture and Fire/Mold/Moisture resistant and a whole other rainbow and brand names.
Old 10-12-2009, 02:34 PM   #26
Trade: State Certified General Contractor
They do make mold resitant drywall its not MR or densheild, please contact your drywall supplier
qualify.com is offline   Reply With Quote
Old 10-15-2009, 10:23 PM   #27
Trade: electrician
what will happen if drywall gets wet?
sparks134 is offline   Reply With Quote
Mold remediation Kostyan General Discussion 17 09-17-2009 07:54 PM
Mold growth on framing? jhark123 Business 24 03-17-2009 02:24 AM
Tile on GP Mold and moisture resistant sheetrock Bill Drywall 3 03-27-2008 08:27 PM
Is anybody using SHEETROCK Tools? Big Bison Tools Drywall 1 11-01-2007 06:47 PM
