This Makes Life A Little Easier
Old 03-13-2006, 05:50 PM   #1
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
I love to use the vaccuum attachment when I'm sanding mud. Don't need a mask, and very little cleanup afterwards. Why don't you guys like it?
ron schenker is offline
Old 03-13-2006, 05:51 PM   #2
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Re: This Makes Life A Little Easier
Who says we don't like it? I use one all the time. I do need to getter a better shop vac, maybe one built exclusively for drywall, but they are mighty pricey.
ProWallGuy is offline
Old 03-13-2006, 06:03 PM   #3
Remodeler
MinConst's Avatar
I also like to use my vac when sanding. The last batch of screens I picked up were fine type but still leave lines. What are you guys using brand wise?
Paul
Minichillo's Construction
Website
I will never leave you hanging!
MinConst is offline
Old 03-13-2006, 06:07 PM   #4
I use a good quality drywall specialty filter in the shop vac... it catches everything. Once I plugged in and starting sanding and didn't realize that someone had used the vac. to suck up water. There was no filter in it at all and I was blowing drywall dust all around the room behind me. not lol
Old 03-13-2006, 09:34 PM   #5
theworx's Avatar
That sounds like the time I bought a new vac (combination blower vac). Put the hose in the outlet (the wrong one) and filled the whole place with drywall dust in about 30 sec's. Doh!!!
theworx is offline
Old 03-13-2006, 10:25 PM   #6
IHI's Avatar
I ought the high dollar shop vac filter and when sanding with attachment is works excellent, but it does seem to load up quickly and then the fun task of shaking that nasty thing out.
I like no vacuum attachment better since the sander is freer to move back and forth across the wall, either that or I need a smaller vac since you exert half your muscle trying to get it to slide at all
If I was in the biz I would have no problem dropping the coin for the orbital sander/vac. tool. I know 1 guy that bought one and says it was his best drywall tool investment to date.
IHI is offline
Old 03-14-2006, 02:25 PM   #7
Drywall Contractor
Mudd Dogg's Avatar
Trade: Drywall Subcontractor
Send a message via AIM to Mudd Dogg
I have the Porter Cable Drywall sander and the Loveless drywall vaccuum. They work awesome, not even the slightest bit of dust until you sand the corner bead. But, and there's always a but, the vac sucks so well (yeah I know how that sounds) that the suction slows down the sander moving across the drywall. I can sand twice as fast without it, but I also use a respirator when not using the vac.
Your right ProWall they are pricey. I got the LoveLess drywall vac for $225 and the PC drywall sander for $430. I wouldn't sand any other way.
Mudd Dogg is offline
Old 03-14-2006, 03:00 PM   #8
Flat and Smooth
Drywall1's Avatar
Trade: Drywall install and finish
OK Mudd Dogg I gotta ask this...
With the porter cable sander do you seem to have problems with swirl marks in the mud and does it rough up the drywall paper next to the joints more so than using a stick sander? I have heard of these issues with this setup and have hesitated on trying it out due to the high cost of the sander.
I'm just very interested in some real world views of this setup. Please give me your opinion. Sorry for taking the thread off course.
Nate
Krieser Drywall
Krieser Insulation
www.KrieserDrywall.com
Drywall1 is offline
Old 03-14-2006, 06:07 PM   #9
Drywall Contractor
Mudd Dogg's Avatar
There is such problems, if and when the person sanding the houses puts too much pressure on the sander along with too course a grit sanding disk. I use 220 sanding discs and have no problems with burning the drywall. Its all in a matter of knowing how to use the machine and what grit disc to use. The quality of the finishing is also a factor. If you have a finisher you just slops the mud on the house and relies on sanding to make it look good, you will definitely have burnt paper.
Once again pole sanding also depends on the finisher. Around here in central Florida I see burnt paper in houses due to pole sanding. I have been told I am the only one in my immediate area that uses the PC sander. So I assume its all pole sanding.
Another note on the PC sander. If you constantly put too much pressure on the machine, it will eventually end up in the repair shop from the motor burning up. You have to let the machine and the sanding disc do the work. Not the muscles in your arms. I've seen it before with too many people using the PC sander like a pole sander.
Old 03-14-2006, 09:11 PM   #10
phinsher's Avatar
Trade: Paint and wallpaper
I agree with Mudd Dogg. We've had ours for a few years and use it many of our repair projects as well as regular drywall projects. After having used 180 on the sander for some time I got used to the nice smooth look it left. While buying new discs for it i decided to get 80 grit (I think) and was appalled at the swirls left behind. We use a regular shop-vac and use the bags that also filter fine dust and it works great for us, much cheaper than the $220 loveless and the Porter Cable shop-vac.
Over-all the sander is one of the best investments I've made in a while (ranks right up there with my airless, and the work van!). But be careful, if you work around homeowners they always wanna know what the heck that thing is. And all your friends who attempt some drywall work will want to borrow it.
phinsher is offline
Old 03-14-2006, 10:32 PM   #11
Flat and Smooth
Drywall1's Avatar
Thanks for the replies guys! Looks like that might be my next tool purchase. Just one thing "speed" how dose it compare with a guy bustin with a pole sander....could you keep up or not?
Nate
Krieser Drywall
Krieser Insulation
Drywall1 is offline
Old 03-14-2006, 11:14 PM   #12
Drywall Contractor
Mudd Dogg's Avatar
You will pass a pole sander like they are standing still with the PC drywall sander.
Old 03-15-2006, 12:16 AM   #13
Flat and Smooth
Drywall1's Avatar
Well Mudd Dogg I'm gonna hold ya to that I'll pick one up after the trip to Mexico at the begining of next week.
Nate
Krieser Drywall
Krieser Insulation
Drywall1 is offline
Old 03-15-2006, 12:18 AM   #14
ProWallGuy's Avatar
Brandwise for screens, 3M, shopvac is a craftsman.
Old 04-03-2006, 04:01 PM   #15
ralo's Avatar
Trade: home improvement
3m?
ralo is offline
Who makes this fire alarm LED box? personalt Electrical 3 07-16-2007 06:50 AM
Life Insurance? dougchips General Discussion 15 07-11-2007 09:16 PM
Life insurance/ investment K2 Off Topic (Non Trade) 1 09-14-2006 04:16 PM
What Makes a Good Company Website? Nathan Technology 18 07-29-2006 08:35 PM
Makes me wonder lxdollarsxl General Discussion 5 05-13-2006 04:18 PM
