Magnesium Oxide Board
Old 05-21-2010, 10:18 PM   #1
singcontractor's Avatar
Trade: building contractor
hi guys
anyone have experience using this board. I have a client that wishes to use this board on the current condo project we are working on.
our original design was to use red brick walls to be plastered on both sides 1 inch thick then to be soffit around 6-8mm as the finishing.
the client recently came back from china and brought in some samples of this board. it is said to have been used in beijing olympic stadiums and also taipei 101.
i have done a little researched and have only found the board used internal and externally over a metal frame work.
i have not found any information on how to install it over red brick walls as its too late for us to go to a metal frame infill wall system with this board used as a finishing.
I would love to hear any suggestions this community would have. I need to find a quick and easy method to install over the red brick which is uneven. If it can replace the labour and material of plastering and sofitting then it will be a new method of doing walls in this part of the world
singcontractor is offline
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task!
Old 05-22-2010, 05:26 AM   #2
Big Shoe's Avatar
Rewards Points: 1,726
Re: Magnesium Oxide Board
Never seen it....seached it briefly, and it appears to be comparable to hardi board.
As far as covering the uneven brick walls , plaster/stucco seems like a better choice.
Good luck
Big Shoe is offline
Old 05-22-2010, 01:20 PM   #3
BuildersII's Avatar
Trade: General
Rewards Points: 250
I'm waiting for something...
BuildersII is offline
Old 05-23-2010, 03:22 PM   #4
mud dog's Avatar
Trade: drywall
Rewards Points: 150
The stuff is very difficult to work with, impossible to finish for paint! It has to be installed using a t-nailer. The plaster's had to score the sheets in order for their plaster to stick to it on the outside of the building. It is coated with a magnesium paint which has to be primed before drywall compound will stick to it. Beware! That being said, if you find a way to use this product let me know, even the company rep didn't have the answers I was looking for. It definitely is NOT a replacement for drywall.
mud dog is offline
The war of plywood VS particle board Jimmy Cabinet Kitchens & Baths 47 09-18-2012 07:52 AM
Rigid Foam Board under sheathing milfordtom General Discussion 27 09-10-2012 04:37 PM
determining skirt board height romoranger Finish Carpentry 2 07-07-2009 01:46 PM
Plywood over particle board PA woodbutcher Flooring 5 03-11-2009 06:09 AM
At we cater exlusivly to professional contractors who make their living as a contractor. Knowing that many homeowners and DIYers are looking for a community to call home, we've created DIY Chatroom is full of helpful advices and perfect for DIY homeowners.
