Loose Tape
Old 04-05-2007, 09:47 PM   #1
wallyofthenorth's Avatar
Trade: painter
Loose Tape
Customer has a vaulted ceiling with 5 angles that all meet into a peek,all of the angles, the tape is cracked or coming apart,homeowner states warmer weather,the cracks almost disapear,I thought insulation problem ,home is 12 years old ,owners have talked to the builder and he says its not insulation problem,just settling.I told them I can patch the problem but next major temputare change it may crack again.Any suggestions or sollutions
wallyofthenorth is offline
Old 04-06-2007, 07:32 AM   #2
Frankawitz's Avatar
Re: Loose Tape
I had a job like this last fall, the pervious drywallers had taped with mesh tape, so when the house expanded the cracks got wider and then when it contracted they got smaller, thing is when this happened the mud fall out of the joints leaving the mesh tape to be seen. I cut all the mesh tape out, opened up the joints and found that who ever installed the drywall they left a 1/2" to 3/4" gap between the board, I filled it with Durabond 90(Brown Bag) then I mix up another batch of 90 for my bed coat, then I used a product called Straight Flex tape it's plastic fiber tape that will not crack open, Try this maybe it'll help with your job.
Frankawitz is offline
Old 04-07-2007, 12:56 AM   #3
Commercial Contractor
Mud Master's Avatar
Trade: Commercial General Contractor
Send a message via AIM to Mud Master
Re: Loose Tape
Yeah Straight Flex is the answer for any off angle or framing irregularities...I find it to be even MORE efficient than regular tape. I would cut out the areas, clean them, and re-finish the area with straight flex.
You may have to build the mud out in order to make it work, and also sand the exsisting paint really good, otherwise your going to have a bonding problem.
Good Luck!
Originally Posted by katoman View Post
And when the day is done, I can look myself in the mirror, with pride, and say " you're a craftsman, well done. "
Mud Master is offline
Old 04-07-2007, 07:37 AM   #4
AtlanticWBConst's Avatar
Re: Loose Tape
Originally Posted by Frankawitz View Post
.....I had a job like this last fall, the pervious drywallers had taped with mesh tape.....
What? Did you catch them in an underwear drawer or something? Looking in neighbor's windows?
- Build Well -
AtlanticWBConst is offline
Old 04-07-2007, 07:38 AM   #5
Re: Loose Tape
3rd vote on the straight flex.....That product is great for straightening out bad corners....
- Build Well -
Old 04-07-2007, 03:28 PM   #6
Flat and Smooth
Drywall1's Avatar
Trade: Drywall install and finish
Re: Loose Tape
Magic Corner from Trim tex. Been using it for 8 years or more. Not one call back since we began using it. If that is not proof enough I don't know what is.
Nate
Krieser Drywall
Krieser Insulation
www.KrieserDrywall.com
Drywall1 is offline
Old 04-09-2007, 12:06 AM   #7
1KingOfDrywall's Avatar
Trade: Drywall, Plaster,Interior Demolitions,Small Repairs
Re: Loose Tape
did the crack go right dowm the middle? or to both sides of the tape?
My standard precedure in that situation is to#1 remove the old paper tape #2 Take a screw gun and run screw in as many areas on/near the seams as possible #3 Apply straight flex with easy sand
Good luck
1KingOfDrywall is offline
Old 04-11-2007, 09:56 PM   #8
jamandbs's Avatar
Trade: painter
Re: Loose Tape
The problem is inadequate venting. Moisture swells the framing, especially trusses, unevenly.
jamandbs is offline
Old 04-18-2007, 02:56 AM   #9
Luke
LukeOR's Avatar
Trade: Drywall
Re: Loose Tape
Ultraflex! A lot stiffer, better for off angles espescially on a main room ceiling. (straight flex works well though and is a little cheaper.
LukeOR is offline
Loose Drywall Tape hanover Drywall 7 12-03-2009 11:43 PM
How do you tape? Al Taper Drywall 10 12-03-2009 11:16 PM
Paper Adhesive tape. jstrand23 Drywall 1 03-07-2007 06:02 PM
18 inch rollers and Tape Question dwbrooks Painting & Finish Work 52 09-08-2006 09:22 AM
Wet tape for corners?? Luke's Dad Drywall 8 03-28-2006 10:28 PM
