Loose Drywall Tape
Old 06-18-2007, 10:53 PM   #1
hanover's Avatar
Trade: Home Improvement Contractor
Loose Drywall Tape
Hi All,
Looked at a repair job today where the drywall tape was actually coming loose from the drywall. Not just in a small area but in a few areas that were 4 - 5 feet long. Other areas were fine. I got hold of a piece and the entire length of tape came off easily. Just the tape....no drywall paper, no paint or anything beyond the tape. All was left was a channel where the tape was previously. Customer said it's been like this for 15 years.
I've never seen this before and wonder if others have and can give some ideas as to why this happened. I'm guessing not enough mud below the tape but if finished with 2 additional coats of compound over the paper (not sure if this was done), would the paper still come away from the drywall and break through any top coats, paint, etc. on its own (as was the case before i pulled if off)?
Thanks for any feedback
Dennis
hanover is offline
Old 06-18-2007, 11:29 PM   #2
oldrivers's Avatar
Trade: drywall applications
Re: Loose Drywall Tape
most likely not enough mud behind tape. The top coats will hold it for awhile but eventually it will loosen up. the moisture from the paint soaks into the top coats of mud and it lets loose.
oldrivers is offline
Old 06-19-2007, 06:16 AM   #3
Professional Remodeler
firemike's Avatar
.. Or they used the wrong material for bedding in the first place. Some materials have very little if any adhesive and are not made for setting tape.
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline
Old 06-19-2007, 05:11 PM   #4
Mater's Avatar
Trade: Drywall
Oldrivers knows.
Mater is offline
Old 06-19-2007, 10:06 PM   #5
hanover's Avatar
Thanks Guys. Appreciate the feedback.
Dennis
hanover is offline
Old 06-21-2007, 12:12 AM   #6
oldrivers's Avatar
but then the problem would be all over the whole house and not just in a few areas. another cause could be the house got taped in the winter and the heat wasnt good enough .
Old 06-23-2007, 03:01 PM   #7
JCardoza's Avatar
Trade: Drywall/Texture
Send a message via Yahoo to JCardoza
I'll agree with the ideas of freezing before it dried, or wrong kind of mud. The most common reason is water damage. But you normally would see some stains associated with that.
JCardoza is offline
Old 12-03-2009, 11:43 PM   #8
Hawaii Handyman Remoleing
Aaron111's Avatar
Trade: Honolulu, Hi Handyman Remodeler 510-868-8807
Send a message via MSN to Aaron111 Send a message via Yahoo to Aaron111
Exclamation
Originally Posted by hanover View Post
Hi All,
Dennis
hopefully you never did that job," im kidding... back in the days most drywallers used topping to tape off everything,"" when you re due this job use AP or all purpose mud ... not topping
Aaron111 is offline
Ceiling Drywall popping and creaking trimco Drywall 12 06-20-2010 09:54 AM
35,000 sq ft of commercial drywall to tape kaiberg Drywall 16 04-13-2008 05:49 PM
loose tape wallyofthenorth Drywall 8 04-18-2007 02:56 AM
18 inch rollers and Tape Question dwbrooks Painting & Finish Work 52 09-08-2006 09:22 AM
Drywall tape DonL Painting & Finish Work 11 04-04-2006 09:14 AM
