Back from the dead...
Trade: Paperhanger/Painter
Levels Of Drywall Finishes
I have recently been contracted to install some very large murals in casinos around the country. In my contracts, I specify that the walls/ceilings needs to be ready for me when I arrive. Ready they are, but I haven't been happy with the finish at all. I need to be more specific to how I need these surfaces to look/feel for a successful install. I have heard of a 'level 5 finish', so I assume there are levels 1-4 too. Can anyone explain or where can I find accurate descriptions of these drywall finishes so I can specify what I need to the architect for these projects.
TIA, any help is much appreciated. |
Chief Toilet Mover
Trade: Bathroom Remodeling
Re: Levels Of Drywall Finishes
Typically level 3 is texture ready, level 4 is paint ready. The majority of walls you have encountered in homes are level 4. Level 5 has had a skim coat of compound applied over the entire surface. This skim coat is what separates a level 4 from a level 5 finish.
Do a search for ASTM C840. There should be a section with the exact wording for levels 0-5. |
Sounds like I have been encountering level 3 or lower.
It gets scary telling the architect that it is NOT a bubble in the vinyl, its the drywall. They don't like to hear that for the $$$ they are dumping on us. Thanks for the link! |
Trade: Paint and wallpaper
usg.com has the "construstion handbook" which also defines level 0-5.
Thanks again. The actual document for the finishes is GA-214-96.
ContractorTalk Flunkie
That is very interesting, I believe I mostly run into level 2 finish work around here! Pro Wall Guy, That is some nice work you do
T.C. "Never met a man yet that I couldn't learn something from"Met a few you couldn't teach though http://remodelingncarolina.com
Drywaller for Hire
Trade: Drywall/Interior Finish
Lafarge just came out with a pre-finished Level 5 wallboard called Rapid Deco L5. It finishes just like regular drywall.
See the link. http://www.lafargenorthamerica.com/w...uct_Rapid+Deco
~a HAVE TOOLS, WILL TRAVEL |
Construction Estimator
Trade: Estimator
You can put a line in your proposal stating walls must be finished to a level 5. There are several ways of achieving this. The easiest is to use a spray application of Sprayplast or Tuffhide. If you inspect the walls with a hallogen light placed at the bottom of the walls shininig up them prior to your installation, this will highlight any imperfections. Take the GC with you when you do this so they "SEE" for themselves. Once you apply your finish whatever it may be paint, murals, paper etc. you've bought the wall and it is now your problem. Make sure the GC tells the drywaller of your needs prior to your starting of the work so they can remedy any imperfections. If the GC wants you to proceed on imperfect walls simply write a letter stating the problem(s) and have them sign off on it. This puts the onus on them!
| Ceiling Drywall popping and creaking | trimco | Drywall | 12 | 06-20-2010 09:54 AM |
| Competitive rates for a drywall crew | airborneSGT | Drywall | 20 | 06-29-2009 09:19 PM |
| Lots of questions about drywall and bathrooms | nobody | Drywall | 30 | 11-27-2008 01:33 PM |
| Transitioning drywall with cement board | Lone Wrencher | Drywall | 19 | 03-02-2008 07:05 AM |
| Window jambs extend beyond drywall | jstrand23 | Remodeling | 21 | 04-27-2007 12:00 AM |
