Level 5 Finish
Old 01-26-2008, 09:04 PM   #1
regal's Avatar
Trade: painting contractor
Rewards Points: 150
Level 5 Finish
spray applied product....... saw it done once......... pros and cons please..
regal is offline
Old 01-26-2008, 09:31 PM   #2
dryrocker27's Avatar
Trade: Drywall Contractor
Rewards Points: 75
Re: Level 5 Finish
hello there regal
Here in my area, the product to use is made by RUCO and is simply labeled EQUALIZER. It seems to me to be a very thin compound/heavy bodied paint that when sprayed, self levels and fills the edges that were not sanded correctly. Only a few guys use it and they seem to get good results with it.
All of my work is done in the residential end of the drywall world in Custom Contract homes. We have been doing level 5 finishing in homes my entire carrier and I have yet to understand what all the fuss is about doing a level 5 finish? All of our ceilings get painted with a Semi-gloss, Walls get done with Egg Shell, and trim is done in High-Gloss.
Maybe somebody else can explain it to me? Well that may be another post one day.
dryrocker27 is offline
Old 01-26-2008, 10:51 PM   #3
Tim0282's Avatar
Trade: drywall contractor
Re: Level 5 Finish
It's simple Dryrocker. You just do a good job and don't need the artificial help from the high build primers. Credit is due you!!
Tim0282 is offline
Old 01-27-2008, 12:25 PM   #4
chameleon's Avatar
Trade: Painting and Drywall Contractor
Re: Level 5 Finish
We just finished a Level 5 in Boulder City, Nevada. But as you know....it all starts with the hangers....No gaps, no ruff cuts....Then obviously, the metal man has to be dead on.....but the tapers have the issues. I always tell the tapers what finish is going to that job, and supervise the initial taping.....after the 3rd coat, a good sand, we used prep coat, then walk the house for blemishes, skim coat as needed, sand again, then spray the Level coat. It self levels, and is also a primer. Ask your supplier about it....it works.
chameleon is offline
5 level of drywall finish jmthouston Drywall 15 10-09-2008 07:30 PM
Sticky finish...Boy could I use some advice Uuber_Framer Flooring 11 10-26-2007 03:41 PM
Why The Bumps Showing in Level 5 Finish Hages Drywall 5 08-15-2007 12:06 AM
explanation for level 1-5 finish D-ball Drywall 2 12-27-2006 03:09 PM
Can You Help Identify This Finish? Richie-C Painting & Finish Work 10 06-07-2006 08:34 PM
