Level 5 D.W. Finish
Old 05-12-2011, 02:34 PM   #1
Brad225's Avatar
Trade: Furniture and custom wood work
Level 5 D.W. Finish
I currently have the drywall in my own home I am remodeling to a level 4 and am looking for someone with experience to apply USG Tuff-Hide or equal products to bring it to a lever 5.
I am located in Wesley Chapel Fl. which is in the greater Tampa Bay area. If any of you can steer me to someone that has experience I would appreciate it.
I tried my USG supplier where all of the materials came from but no luck so far.
Thanks
Brad
Brad225 is offline
Old 05-12-2011, 02:48 PM   #2
PRO
BrandConst's Avatar
Rewards Points: 1,000
Re: Level 5 D.W. Finish
I've used tuff hide before, not a big fan of it. I've learned that pulling a tight float on the entire surface, then sanding and then check with a spot light upclose and touch up as needed will get you where you want, my drywall sub does a great level 5 but I'm in TX. this is what the does, not cheap by any means. I try to talk people out of it because you can never patch the wall with out having to redo the whole wall.
BrandConst is offline
The Following User Says Thank You to BrandConst For This Useful Post:
Chris@Sunrise (05-12-2011)
Old 05-12-2011, 02:49 PM   #3
Custom Builder
Chris@Sunrise's Avatar
Rewards Points: 502
Level 5 in residential. Why
Chris@Sunrise is offline
Old 05-12-2011, 03:58 PM   #4
rjconstructs's Avatar
Trade: Residential remodel
Rewards Points: 168
I'm not familiar with the description and details of each level of drywall finish. Can anyone enlighten me?
rjconstructs is offline
Old 05-12-2011, 04:03 PM   #5
Anti-wingnut's Avatar
Rewards Points: 3,310
http://www.gypsum.org/pdf/GA-214-M-97.pdf
Anti-wingnut is offline
The Following User Says Thank You to Anti-wingnut For This Useful Post:
rjconstructs (05-12-2011)
Old 05-12-2011, 04:03 PM   #6
Fire up the BBQ
griz's Avatar
Rewards Points: 1,792
griz is online now
Old 05-12-2011, 04:04 PM   #7
Ha ha, beat you
Old 05-12-2011, 04:05 PM   #8
And you're a moderator too.
Does that mean I get your job now?
Old 05-12-2011, 04:09 PM   #9
Fire up the BBQ
griz's Avatar
Lucky shot
You want this job???
griz is online now
Old 05-12-2011, 05:48 PM   #10
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,205
I am located in Wesley Chapel Fl. which is in the greater Tampa Bay area. If any of you can steer me to someone that has experience I would appreciate it. I tried my USG supplier where all of the materials came from but no luck so far.
Thanks
Brad
Brad, You could message Willie T on here.
He's in St. Petersburg. But, Willie might be able to steer you in the right direction.
-Paul
-Paul
TextureMaster.com
Checkout my YouTube Channel with 20,000 Subscribers and over 5,000,000 Views
https://www.youtube.com/paulpeck
Twitter Facebook Google+ Instagram
Sir Mixalot is online now
Old 05-12-2011, 08:03 PM   #11
Brad225's Avatar
This is something my DW contractor is pushing to give me a great smooth finish based on the request of mine to have virtually flawless walls. I had never heard of it prior to this.
I have always sponged the entire wall with water and a bit of compound to lay down any scuffed paper then primed and touched up from there.
Brad225 is offline
Old 05-12-2011, 08:06 PM   #12
Brad225's Avatar
That is a good point about repairs. I would think it would be the same for both Tuff Hide or skim coat and sanding. I wish I didn't dislike texture so much.
Brad225 is offline
Old 05-12-2011, 08:32 PM   #13
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Level 5 is unnecessary in a home. Most homes get level 3 at best. Your drywall guy is pushing this because it makes sense for him. Get more estimates.
http://www.ohiohomedoctorremodeling.com
ohiohomedoctor is offline
Old 05-12-2011, 08:50 PM   #14
Painting & Remodeling
JHC's Avatar
Rewards Points: 516
If the customer wants lvl 5 give it to him. Maybe he wants furniture quality walls. Jeeze I hope you guys don't tell you clients you don't need the best.
Aaron with Integrity finishes of Tampa may be able to help you. If not he can recommend a qualified contractor that can.
JHC is offline
Old 05-12-2011, 09:36 PM   #15
Custom Builder
Rewards Points: 502
I agree if thats what they want give it to them and charge accordingly, I figured this might be a HO that doesnt know the difference. I just saw a guy want level 5 finish and then a heavy hand texture over it. He had three pages of scope of work just for the drywaller, this is for a house mind you nothing tricky.
Old 05-12-2011, 10:04 PM   #16
That is sadly true. But if you read the book, you'll learn that Level 3 should be the minimum where a textured wall is the final finished product
Old 05-12-2011, 10:06 PM   #17
Your drywall guy is pushing this because it makes sense for him. Get more estimates.]
It's the OP's own house. I'm sure he knows what he wants
Old 05-13-2011, 01:40 AM   #18
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,168
I use a drywall guy that pushes the same thing on remodels. But only near areas where it is transitioning to the old walls, if I'm taping an entirely new room, then I will only tape the seams. You have to look at your focal points too when you judge how much mud is needed where. Don't do a level 5 in a closet, I'm sure your drywall guy would agree.
kenparsonscontracting.com
KennMacMoragh is offline
Old 05-13-2011, 06:34 AM   #19
Brad225's Avatar
Aaron withIntegrity finishes of Tampa may be able to help you. If not he can recommend a qualified contractor that can.
I spoke with Aaron yesterday and the guy he knows that does is won't drive the 45-60 min it would take to get here. That's his choice, no bad feelings here.
Brad225 is offline
Old 05-13-2011, 06:39 AM   #20
Brad225's Avatar
Yea, I'm pretty obcessed but the closets would be a bet much. I talked with a highly recomended painter yesterday. He is going to come by on Sat to give me some information on different products and cost.
Brad225 is offline
EXT, finish choices genecarp Painting & Finish Work 19 12-08-2008 03:47 AM
How much to charge for level 5 finish vs level4 AARC Drywall Drywall 8 10-23-2008 11:12 PM
Level 5 finish?? beapainter Drywall 3 09-29-2008 05:12 PM
level 5 finish regal Drywall 3 01-27-2008 12:25 PM
Why The Bumps Showing in Level 5 Finish Hages Drywall 5 08-15-2007 12:06 AM
