Laminating Screws Secure?
Old 05-12-2010, 07:37 AM   #1
Ted White's Avatar
Trade: Soundproofing
Rewards Points: 79
We spec a good number of walls and ceilings with two and three layers of 5/8" TypeX for soundproofing. Different length standard drywall screws have always been spec'd to go back to original framing (stud, joist or metal track).
Last week a contractor called from a job and insisted on using laminating screws on the third layer. He does this routinely to "have a more stable finish."
Is this a normal practice? Tests that we did with laminating screws a few years ago left me questioning their security and value.
Ted White is offline
Old 05-12-2010, 11:53 AM   #2
D.Foster's Avatar
Trade: Carpentry & Remodeling
Re: Laminating Screws Secure?
Laminate with PL glue, and laminating screws? A screw that would go clear through the 2 layers underneath though.
Not speaking from experience though
Would seem like more work though than just hitting the layout...
Do what you would do, as if i won't Do anything after you Did It!
D.Foster is offline
Old 05-12-2010, 11:58 AM   #3
Ted White's Avatar
Rewards Points: 79
The issue is the damping compound used between the drywall layers (3 layers) isn't an "adhesive" and takes a few weeks to set up. So the ceiling is essentially exclusively relying on the laminating screws for the first couple of weeks.
This isn't at all what we recommend, but the sub was adamant that he would not use standard drywall screws on the final layer.
Old 05-12-2010, 08:37 PM   #4
Big Shoe's Avatar
Rewards Points: 1,748
I never really cared for them. Used them alot in the old days. Only on walls though.
Don't think I ever tried them on ceilings. I would'nt trust them to hold.
I always go with longer screws to hit the studs.........whatever it takes.Someone will dig up the specs on them I hope.
Big Shoe is offline
Old 05-12-2010, 09:22 PM   #5
Ted White's Avatar
Rewards Points: 79
That seems like a good all around assessment.
Old 05-12-2010, 09:32 PM   #6
Bradyn
Axecutioner-B's Avatar
Trade: Arizona remodeler
Rewards Points: 75
Is 5/8 typeX different from regular 5/8 wallboard ? If not i can't see why anything different from a regular drywall screw would be used. If its good enough for almost every sheet of drywall in America why wouldn't it be good enough for a second or 3rd layer? I don't get it & i don't like it. Just my .02
Now i will have to do a search to see what a laminate screw & typeX are so i will know if i just put my foot in my mouth
Ok just checked, Hell no !! I would MUCH rather have the screws & the drywall be attached to the structure rather than to just drywall alone.
What do i know tho, i only have 2 cents
Not to mention the screws holding the first layer will have more & more of a load on them after each layer if the additonal layers are only screwed to the first layer & not to the structure. How many layers can the first layer screws hold before they fail if they are supporting the entire load? You know what i mean?
Axecutioner-B is offline
Old 05-13-2010, 01:02 PM   #7
Ted White's Avatar
Rewards Points: 79
I haven't found any pro that would recommend using laminating screws only. Not one.
I sure appreciate all the opinions.
The Following User Says Thank You to Ted White For This Useful Post:
Big Shoe (05-13-2010)
Old 05-13-2010, 01:13 PM   #8
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
I would think a lam screw into 1-1/4" of rock(2 layers) would hold pretty well, but if you tested them and didn't like them, well ....
There might be some merit to this method though... screws through framing would transmit vibration(spelled sound)... it's a sound wall..
-Steve
TimelessQuality is offline
Old 05-13-2010, 01:16 PM   #9
Ted White's Avatar
Rewards Points: 79
That's a good point about the length of the laminating screws. I would wager he was using lam screws designed to go onto the second layer and that is all.
The three layers are hanging on a decoupled track, so no concern about screws and conduction.
TimelessQuality (05-13-2010)
Old 05-17-2010, 11:52 AM   #10
JeffeVerde's Avatar
Trade: G.C.
I dont' have a spec sheet handy, but if you're using GreenGlue, I'm pretty sure they recommend using lam screws and not screwing 2nd/3rd layers into the framing. But that's for the purpose of decoupling from the framing, which you're addressing with your decoupled track.
On a ceiling, I'd glue/screw the first layer to the "framing" (or track in your case), greenglue and screw the second layer to the framing, and greenglue and laminate-screw the final layer.
JeffeVerde is offline
Old 05-17-2010, 12:33 PM   #11
Ted White's Avatar
Rewards Points: 79
Thanks for the thought. Actually, the manufacturers literature does not recommend laminating screws. All screws go back to the framing, whether that's a track, stud or joist.
The decoupling is accomplished with the track, as you pointed out, so no benefit by looking to omit framing screws.
Axecutioner-B (05-17-2010)
GRK Torx-Head Screws - Anyone Else Like Em? BuildersII Tools & Equipment 25 02-20-2010 10:50 AM
Screws popping after 4 months bruclark Drywall 11 12-15-2009 12:26 PM
Deck Screws vs Joist Nails subybohn Decks & Fencing 100 11-25-2009 02:52 PM
Slotted screws and other peeves! WNYcarpenter General Discussion 31 10-10-2009 11:30 AM
How many screws does it take to secure a door jamb? Dustball Remodeling 28 02-21-2008 04:03 PM
