Paul
Trade: Hard Surface Flooring
Rewards Points: 1,004
Knockdown Over Existing Paint?
Hey guys, couple of questions about the current project going on the home-front right now. First off, this is my house not a customers so it ain't gotta be perfect. That being said I'm a perfectionist and am more than willing to do it right.
I'm painting the new to us house prior to moving in. The drywall is (imo) pretty rough shape. Nail holes galore, multiple diy re-paints complete with runs/drips everywhere, etc. If i wanted flat/smooth walls there would be tons of skimming involved. The wife and I both agree that a knockdown finish is acceptable and probably less labor. All rooms that would be textured are flat except for the master which is an eggshell/satin. I have access to a hopper gun setup but for a whole house I am considering renting a spray rig. Right idea? Do I need to prime prior to spraying the texture? Can the walls be run over with a pole sander? What method do you guys use over existing paint? Any tips, ideas, warnings very much appreciated. If it matters, the new paint is SW MasterHide low-lustre. I intend to use tinted primer prior to painting.
Precision Floors (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
Trade: General Contractor - ret.
Re: Knockdown Over Existing Paint?
In doing repairs and patches, I've never had a problem with texture sticking to painted surfaces, so I wouldn't worry about any special prep other than to vacuum the walls well to get rid of any dust and loose surface debris. If there is any damage, nail holes, etc., to fill or repair, do that as well, followed by a final vacuum.
When you spray the texture, go with topping compound that's been thinned just enough to make it flow through the gun/hopper. The premixed compound is smoother and won't have any dry balls in it, unlike trying to mix the powdered texture in a bag. Advertisement |
Paul
Yeah, I figured a thinned pre-mixed mud would probably be the way to go. Spray rig or hopper? Coverage rate guesstimates?
I've never used a spray rig, only a hopper and air compressor. The major difference between the two is a hopper you carry the weight, a spray rig holds the mud and you just wave a hose and nozzle around. Other than that, I don't know.
Trade: drywall contractor
Spraying knockdown over paint is tough. Well the spraying part is easy enough, it's the knockdown that is hard. It always wants to slide, so you don't get much texture out of it. When spraying over drywall, the mud soaks in just a little. Makes it a lot easier. But you don't have that advantage. If you are going over flat paint, and you said most of it is, you'll be better off. You might want to prime the room that is satin finish. About the hopper compared to a spray rig. A hopper does a fine job. Probably not worth renting a rig. I'd still go with the bag mud that is designed for knockdown. Just mix it kinda stiff the day before and put a little water on the top. Soaks the lumps out. It stands up better, doesn't shrink as much. And since it is made for texture, it doesn't have the air holes in the finished product from thinning like the premix does.
The Following User Says Thank You to Tim0282 For This Useful Post: |
aptpupil (11-09-2010)
#6 | |
Trade: painting
Re: Knockdown Over Existing Paint?Quote:
#7 | |
Paul
Trade: Repair and remodeling
Rewards Points: 95
If you want to do it right, prime before and after. Use a bonding primer like grabber. I have not rented a texture machine before but, if it is not too much, I would go for it. Holding that hopper can get heavy after awhile.
#9 | |
Another tip for the OP, you can control the texture size in two ways, by changing the nozzle diameter and by controlling pressure. Do some practice spots after you're set up and ready to go to get the feel of the texture unit and the tip/psi settings. Play around with things a bit until you get what you're looking for. You can practice on your wall and just wipe it down afterwards with a wet rag for a clean slate or use a scrap of plywood or drywall and throw it away when your done. I mentioned vacuuming earlier. Make sure you vacuum up any debris/dust on the floor that will get blown up and onto the wall. Same goes for window ledges, etc. Tarp everything off with blue tape and painters plastic. Have a hose and clean up buckets at the ready before you start spraying. Texturing isn't all that difficult, but I would recommend starting in a back room until you get the hang of it. |
#10 | |
Paul
You are welcome.
#12 | |
Trade: drywall
Rewards Points: 31
A way around that is to spray a very light coat on the wall and let it dry, then come back and give it the money shot. The light coat will give the second, heavier coat something to stick to.
Trade: Florida Certified Building Contractor
Just another thought. Covered up lots of hundred year old plaster. Switched years ago to lite weight joint compound thinned with ZILZ rather then water. Never a problem. Not as fussy as dry mix texture.
#15 | |
Trade: drywall
Rewards Points: 31
#16 | |
#17 | |
Trade: drywall
Rewards Points: 31
#18 |
See there, I'd never consider skip troweling in residential. I've seen it and done it, mind you, but it's too "industrial" because that's what you see in all the commercial buildings. For me, it's also a PITA to do and I hate watching my drywall guy make it look so easy! LOL
![]() I feel the same way about radius corners as I do about orange peel texture. It's not that it can't be elegant and very nice, but most of the time it just cheapens the look and feel of a house. In high end homes it works, in Joe Average's $200K cookie cutter tract box, not so much. ![]() |
#19 |
Rewards Points: 1,732
I would hire somebody to skim the walls for you. You will be happier in the long run.Use good flat or satin paint too.
I don't care for knockdown walls. too gaudy on walls and dated. May hurt resale down the road. Hire a pro. ![]() |
#20 |
Trade: painting
One of the pros that I work with has a different approach to this. He shoots on multiple coats of orange peel, then uses his PC drywall sander/vac combo to bring it back to a smooth surface. It works great, and it's nearly all "machine work".
Advertisement |
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
paint flaking from the ceiling...cause/solution?? | lornmastro | Painting & Finish Work | 27 | 02-26-2012 10:01 PM |
EPA Lead Based Paint Certification Training THIS MONTH--Indianapolis | ChrWright | General Discussion | 14 | 11-16-2011 04:36 PM |
How to paint typical aluminum Garage Door | IHI | Painting & Finish Work | 2 | 12-28-2009 07:58 AM |
question about SW paint choices | AustinDB | Painting & Finish Work | 5 | 06-21-2009 09:14 AM |
Short Review Of Aura Paint | Riverside Paint | Painting & Finish Work | 30 | 03-07-2009 07:50 PM |
Go to Page... |
