Trade: Builder/Designer
Knockdown Order
Does new drywall need to be sprayed with a primer before I spray on knockdown texture or do I put it on after.Can you guys give me some tips on this. Thanks
Deck Designer/Builder
Re: Knockdown Order |
| The Following User Says Thank You to DecksEtc For This Useful Post: | woodlover (02-04-2009) |
Profit is not dirty.
Trade: Residential Drywall and Taping
Re: Knockdown Order
We spray the ceiling before we knock it down, and once its knocked down, its done. Some people use a oil base and spray it on once its knocked down, but its only in the bathrooms.
Profit is NOT a dirty word....Cheap is.... |
| The Following User Says Thank You to AARC Drywall For This Useful Post: | woodlover (02-04-2009) |
Re: Knockdown Order
If you don't prime first, the taped joints will absorb the moisture out of the texture faster than the areas that don't have mud on them. This will create an uneven pattern in your knockdown. Priming first eliminates this issue.
#5 | |
Smart phone? Scan me!
Trade: Painting/Framing/Drywall
Re: Knockdown OrderQuote:
yep, and even when just spraying up acoustical, seams will show much the same way. |
Trade: Residential & Commercial Hanger/Finisher
Re: Knockdown Order
Just a ? on knockdown texture. Here in TN we don't do a lot of it & Its few & far between. What knife do you guys use to knock it down? I bought one of these http://http://www.texmaster.com/spectools.html & it seems to work ok. I'd like to hear what the pro's that do this everyday use since I get stuck with mostly "slick" EVERYTHING!!
| Spray Knockdown Problem. | Drivetech | Drywall | 22 | 07-02-2011 11:25 AM |
| Knockdown Texture Patch - Flashing? | mseneker | Drywall | 7 | 05-18-2009 12:47 PM |
| Knockdown texture | bkconstruction | Drywall | 2 | 01-17-2009 11:23 AM |
| Favorite knockdown knife | Tradesman | Drywall | 7 | 10-15-2008 09:57 PM |
| Change Order fees for Residential General Contractors?? | SBI | Business | 6 | 09-29-2008 04:09 PM |
