Trade: Remodel
Knockdown-fog Coat First?
I remember seeing a house where knockdown was being applied that they did a fog coat first(sprayed texture in a manner that resulted in a very fine texture finish). After drying, they sprayed again and did the knockdown.
Is doing a fog coat a good idea? |
Trade: Drywall, Plaster,Interior Demolitions,Small Repairs
Re: Knockdown-fog Coat First?
waste of time. Unless the area underneath the "fog coat" is really bad and in need of a tack coat or something......not sure why anyone would waste their time. Was this a restoration project?
Trade: drywall. framing. plastering
are you sure it wasn't primer?
Trade: Remodel
Thanks for replies. Sounds like it is not a recommended step.
It has been several years ago when I observed them spraying, and they said that they were doing a "fog" coat. It was new construction. |
you said it was a few years.....any chance your memory is getting a little "foggy"....hehe
On a serious note though, as I said I never really heard of that. Sometimes on a ceiling that is already painted for example, you need a tack coat-something the texture can stick to and dry to. I have pre sprayed a surface with easy sand durabond with a fine mist and when that dried, I lightly sanded and applied the desired texture.?? Oh well, hope this helped out. |
Trade: Remodel
Yes, the memory may be somewhat foggy. Liked the humor.
| 1 coat vs. 3 coat stucco finishing | janrickey | General Discussion | 12 | 07-17-2011 11:22 AM |
| Stucco Finish coat seperating from base coat? | mwcuff | Masonry | 9 | 08-16-2008 08:42 PM |
| Spray a coat of knockdown on a driveway | 4thGeneration | Painting & Finish Work | 1 | 03-24-2007 06:16 PM |
| 2 coats or one coat | saucedo80 | Painting & Finish Work | 38 | 03-02-2007 08:23 PM |
| Second Coat or not | cowtown | Painting & Finish Work | 16 | 05-24-2006 06:05 PM |
