Keeping Sprayer Thawed
Old 11-29-2007, 09:44 PM   #1
CrazyTaper's Avatar
Trade: Drywall Finisher
Does Anyone Have Any Advice On Keeping Your Sprayer From Freezing? Winter Is On Its Way-and From The Garage To The Jobsite Can Do A Number On Them. I Generally Run Kerosene Through It The Last Step After Pumping It Out With Water. I Close The Pump Valve To Keep It Full. I Have A Hydrapro Iv(gas) And Pump Out Of A 55 Gallon Drum. I Need Some Advice Also On A Smaller Sprayer For Basements And Additions- (electric)-what Do You Recommend?
CrazyTaper is offline
Old 11-30-2007, 07:49 AM   #2
Frankawitz's Avatar
Re: Keeping Sprayer Thawed
Crazy when I use to spray a lot we would run Prestone anti freeze into the pump. I don't know if that's what you where looking for. good luck
Frankawitz is offline
Old 11-30-2007, 11:25 AM   #3
Professional Remodeler
firemike's Avatar
I always run mineral spirits through mine, keeps them lubed up and protects from freezing as well.
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline
Old 11-30-2007, 12:12 PM   #4
Thom
thom's Avatar
mineral spirits mixed with 30 weight oil. Leave that in the pump, drain the hoses after each use.
thom is online now
Old 11-30-2007, 12:51 PM   #5
georgiamudman's Avatar
Trade: Drywall
anti-freeze (ethylene glycol)
or Calcium Chloride powder could be mixed into your material.
Either of these will lower the freezing point.
You could just move south.
georgiamudman is offline
Old 11-30-2007, 09:28 PM   #6
CrazyTaper's Avatar
thanks for the advice-I usually spray 2 houses a week and if she goes down-I'm cooked.
Old 12-01-2007, 07:09 AM   #7
firemike's Avatar
Exactly the reason to invest in a backup pump. I had a packing blow right in the middle of a spray job once, happened on a weekend, naturally couldn't find parts. Decided right there and then to purchase a second pump. It's just a little Graco 395, but at least it will pump paint if the big one goes down, and I have actually found it handy to use on smaller jobs rather than hauling out the big one.
-Mike-
Falcon Contracting
firemike is offline
Old 12-01-2007, 08:54 PM   #8
dryrocker27's Avatar
Trade: Drywall Contractor
We use a 7 x 16 enclosed trailer to store and keep tools on the job-site. we put any tapetech tools that may freeze in the trailer at the end of the day and place a small electric heater in the trailer to keep the trailer at a constant 50 degrees. we also run kero reddy-heaters on a thermostat set at 45 in the house to keep the compound on the drywall from freezing. we work in residental housingand this has worked quite well for us.
Robert
dryrocker27 is offline
Graco / Magnum XR7 Airless Paint Sprayer $285 ATLT Contractor Swap 0 11-27-2007 10:03 AM
Spray King Sprayer for sale JCardoza Tools & Equipment 0 11-05-2007 06:54 PM
Cost tracking and record keeping Tom M Business 11 05-21-2007 07:37 AM
new sprayer Traditions Painting & Finish Work 2 01-19-2007 02:25 PM
cleaning out your sprayer aspenpainting Painting & Finish Work 7 04-24-2006 11:03 AM
