Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Drywall
Old 10-26-2007, 10:50 AM   #1
Mitch the Handyman
bujaly's Avatar
Trade: Handyman
Inside corners are crackin.??.
Question that I'm not sure the answer of.. Actually, TWO questions I'm not sure the answer is..
Customer called to paint a kitchen and a stair way hall in a townhouse, not an end unit either.. Pretty cut and dry, BUT... The inside corners are all cracked and very visible. Heck, at one point you can actually see the tape "twisting" OFF in the middle. (if you can envision that).
My questions are as follows and I know you all don't have ALL OF THE info you might need, but you all can humor as you always do.
1. What causes this typically? Settling, shoddy taping, incorrect methods..blah,blah..
2. Lets say it is due to settling or whatever... If I take all the tape off and re-tape, will this just keep happening?
"Relentless in Reliability and Satisfaction!"
Oh yeah, 1 other thing...
Assuming doesn't make an a55 out of me and you, it makes an a55 out of YOU and YOU!!!
bujaly is offline   Reply With Quote
Old 10-26-2007, 11:08 AM   #2
MODERATOR
ProWallGuy's Avatar
Trade: Paperhanger/Painter
1. Usually settling causes this, especially if it looks like the tape is 'twisting' off.
2. Remove tape, re-tape, and don't guarantee it. You can't. You have no idea if it's done settling. That's about the best you can do. I never guarantee repairs on stress cracks.
ProWallGuy is offline   Reply With Quote
Old 10-26-2007, 12:23 PM   #3
Al Smith
A W Smith's Avatar
twisting off is a sure sign of one wall moving in the opposite direction of the other. You cannot guarantee it. just cut out one end of the tape and peel it off. Some light cracks on a corner tape edge I just flat tape over to allow it to move slightly.
A W Smith is offline   Reply With Quote
Old 10-26-2007, 01:34 PM   #4
Mitch the Handyman
bujaly's Avatar
Trade: Handyman
I'm not following you here. Do you do this if it's just light cracking in general or..?
Old 10-26-2007, 01:40 PM   #5
Al Smith
A W Smith's Avatar
No what I mean is on inside corners that have limited cracking on only one edge of the tape. I flat tape over that crack so the center of the tape is over the crack. any crack over 16 - 24 inches long or so i cut out the corner.
Old 10-26-2007, 01:48 PM   #6
Mitch the Handyman
bujaly's Avatar
Trade: Handyman
I gotcha.. I wish, these cracks are about 15 ft long..
Old 10-26-2007, 04:40 PM   #7
I'm just guessing here, but you're talking ceiling angle?
neolitic is online now   Reply With Quote
Old 10-26-2007, 05:06 PM   #8
Al Smith
A W Smith's Avatar
i was thinking the same thing. "townhouse" hmmm... trusses?
Old 10-26-2007, 05:33 PM   #9
owner
drywallet's Avatar
Trade: Hanging, Taping, Custom, Repairs, Scrapping
What kind of tape is it? mesh or paper. I've seen more cracks when Mesh has been used on angles. I was tought to never tape with mesh on the angles.
drywallet is offline   Reply With Quote
Old 10-26-2007, 06:44 PM   #10
Mitch the Handyman
bujaly's Avatar
Trade: Handyman
No, no angles here.. From the bottom of the stairwell to the top of the second floor. The stairwell starts at the bottom of the first floor. It's paper tape, of course..
Old 10-26-2007, 06:51 PM   #11
Pull a piece off, you can tell if there was never any mud behind it. I f there was then it's probably a movement/shrinkage problem like mentioned before.
Inside corners.... bujaly Drywall 11 08-15-2007 08:36 PM
auto tool for inside corners MagnumBI Drywall 3 06-22-2007 06:42 PM
Painting inside corners gtcway Painting & Finish Work 6 07-05-2006 08:20 PM
crown inside corners Nutty Carpentry 4 03-19-2006 12:59 PM
Question about inside corners Lone Wrencher Drywall 36 12-08-2005 07:37 PM
