Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Drywall
Old 12-23-2007, 12:38 AM   #1
Trade: drywall contractor
Icynene Foam Insulation
Do you guys have an opinion on the spray foam on the ceiling? Seems to me it is a vapor barrier on the ceiling. I thought we got rid of that problem in the eighties. Do you have it in your areas?
Tim0282 is offline   Reply With Quote
Old 12-23-2007, 01:04 AM   #2
mdshunk's Avatar
Are you saying that you don't want a vapor barrier on your ceilings for some reason?
mdshunk is offline   Reply With Quote
Old 12-23-2007, 11:49 AM   #3
Sure don't in Iowa. Too much humidity and temp change. Causes joints to peek too much. Traps the moisture between the rock and the plastic. Unless, you have a whole house fresh air intake, then it seems OK. I've removed enough rock over the years from ceilings and seen the mold between the rock and plastic. Seems like a problem to me.
Spray foam insulation Mike Finley Insulation 17 10-11-2009 02:53 PM
Spray foam insulation? tgeb Insulation 5 12-16-2007 11:11 PM
foam insulation daneosporin Masonry 1 08-09-2007 02:35 PM
Any Icynene Insulation Installers Here? thepawnshop General Discussion 11 10-23-2006 02:24 PM
fastening wire + wrap to foam insulation mas Construction 0 07-07-2006 09:39 PM
