I Need Some Tips On Creating A Skip Trowel Texture
Old 01-25-2006, 10:50 PM   #1
saucedo80's Avatar
Hello I am a painting contractor just begining to do texturing as well. I need some tips on how to create a satisfactory skip trowel texture. Any tips would be appreciated
saucedo80 is offline
Old 01-26-2006, 01:02 AM   #2
Custom Builder
Glasshousebltr's Avatar
Re: I Need Some Tips On Creating A Skip Trowel Texture
Find a topless dancer and have her play bumper thumper while the walls are still wet. .......Then post the pics here.
Bob
Bob
Glasshousebltr is offline
The Following User Says Thank You to Glasshousebltr For This Useful Post:
skyhook (01-16-2010)
Old 01-26-2006, 01:50 PM   #3
KingOfDrywall's Avatar
Here is a simple method. I'm assuming first that it is new drywall correct?
Ok....get a few buckets of plus 3.....add about 2-3 cups of wter and mix it for a good 1-2 minutes onn high speed. Get a paint roller (with a large nap on it) and roll product on the walls. It should be going on pretty thick. Just get the product on a wall as fast as possible (I usually have 2 guys rolling in front of me) With a 10" knife, just glide it across from left to right very lightly just to somewhat flatten the area that was mudded (doesnt have to be perfect at all)now quikly go back in a random pattern "skipping"that 10" knife lightly. DO NOT stand knife up as it will remove too much mud. kinda lay it down as you skip. Do small arches,crosses etc....just mix it up and try to keep the consistency even and it should come out ok. Best of luck hope I helped.
KingOfDrywall is offline
Old 12-11-2009, 05:42 PM   #4
Build it better
rkaitz's Avatar
Trade: General Contractor/Carpentry
I have tried skim caoting witha roller, but even though I have tried this with varied amounts of presure and different vicosities of mud it only will roll for a short distance. It will slide at that point. Am I a "tard"? I have also tried to change the nap thickness as well.
rkaitz is offline
Old 12-12-2009, 10:10 AM   #5
Profit is not dirty.
AARC Drywall's Avatar
Trade: Residential Drywall and Taping
go on to ebay an purchase the cd on texturing...
or better yet get the tex machine and a sheet of drywall and practice.
to start you can use a compressor about 50 psi and get a tex gun...mix (we use) kal tex to the manufacture spec
then practice..when ready just skim across the texture. if its to wet you will get ribs as you finish your stroke.
Profit is NOT a dirty word....Cheap is....
AARC Drywall is online now
Old 12-12-2009, 10:15 AM   #6
genecarp's Avatar
Get a high end roller, it cant be an old paint roller. GMOD
genecarp is offline
Old 12-12-2009, 04:36 PM   #7
Capt-Sheetrock's Avatar
Trade: Drywall
Dern, I wish ya hadn't said that, i was gonna say, I find they roll better with a cheap roller than a exspensive one. Oh yeah, and thin the mud out
Capt-Sheetrock is offline
Old 12-12-2009, 08:30 PM   #8
genecarp's Avatar
Capt, i guess what i was thinking, when he said the roller would start to slide instead of roll, i pictured an old roller with paint residue built up on the shaft, sometimes they get a little stiff in the role dept. I am sure a cheap one, if it was not bent and was clean, would do the job, GMOD
genecarp is offline
Old 12-16-2009, 09:24 PM   #9
Damonceles's Avatar
Trade: Drywall Sub
we always use a 20oz dipper cup 2.5-3 cups water about a half-3.4 cup of fine sand per box of heavy mud. then get a small amount on a 12-14 and slide it against the wall steadly leting the sand in the mud make it skip dif spots. takes practice for sure and no 2 people do it the same from my exp
some people make tiger stripes others are a speckly knock down looking stuff i do a swirly seashell looking thing and make these spiral vortexs
Damonceles is offline
The Following User Says Thank You to Damonceles For This Useful Post:
Axecutioner-B (07-06-2010)
Old 12-16-2009, 09:25 PM   #10
Damonceles's Avatar
Trade: Drywall Sub
sry 1/2-3/4 cup sand kindav unclear when i reread it
Old 12-16-2009, 09:50 PM   #11
Drywall & Painting Pro
Sir Mixalot's Avatar
Trade: Hang, Finish, Texture, Paint, and Repair.
That's how we do it here. But, "skip trowel" is a regional thing. It can be different texture depending on where you are located around the country.
Here's ours:
Sir Mixalot is offline
The Following User Says Thank You to Sir Mixalot For This Useful Post:
Axecutioner-B (04-08-2010)
Old 12-17-2009, 04:34 AM   #12
Build it better
rkaitz's Avatar
Sir Mixalot...That is exacly the same texture in the oicture that I need to match, Guess I better practice the method. So if I buy a box of topping.....what screen size of sand is it? And how much water?
Thanks,
Rick
rkaitz is offline
Old 12-17-2009, 09:01 AM   #13
Thanks,
Rick
Around two cups of sand and roughly 2 cups of water.
I should mention I use a hawk and knife to achieve this texture.
Old 04-07-2010, 06:05 PM   #14
artinall's Avatar
Here's another style of doing the skip trowel that may help, to get another effect. http://www.drywalltips.org/skip-trowel-texture-technique.htm
It's heavier with more variation. All depends on personal tastes.
artinall is offline
Old 04-11-2010, 05:13 PM   #15
ratherBfishing's Avatar
Trade: finish carpentry
i dont ues sand..just thin the mud and a real light touch..i like smooth finish not sandy like stucco
its just prefrence..
ratherBfishing is offline
Old 04-11-2010, 06:49 PM   #16
LET ME SHOW YA SOMETHIN!!
CrpntrFrk's Avatar
Trade: I do that too!
Wow. I guess I have lived skip texture for so long I thought it was a main stream kind of thing. Here there are so many different types of skip. Directional, cross skip, curve skip, etc. Also how thin you get the mud makes a huge difference. I use a 18" curved knockdown knife and pan to achieve any type of skip texture. If you are doing new construction I also like a 24" knife and pan.
DO IT!! DO IT!! DO IT!!
CrpntrFrk is offline
Old 04-23-2010, 02:08 PM   #17
MUDBUCKET's Avatar
Trade: DRYWALL CONTRACTOR/TAPER
It is funny that textures that are common in parts of the country are rare in others . I've been taping new houses for over 20 years and never done or been asked to do a skip trowel texture.
MUDBUCKET is offline
Old 07-06-2010, 11:07 PM   #18
boy howdy's Avatar
Trade: painting & drywall
I agree, it's everywhere in MS, haven't seen it yet in FL. We spray a heavy splatter and knock it down. (Pensacola, FL) Then again, we are the only one's I've seen that do a stomp ceiling around here too.
boy howdy is offline
Old 07-07-2010, 06:52 AM   #19
Frankawitz's Avatar
When it comes to using a roller to apply your mud have any of you guys tried a textured roller skin? it will hold a lot more mud then a paint roller skin, I use them all the time
Frankawitz is offline
The Following 2 Users Say Thank You to Frankawitz For This Useful Post:
Axecutioner-B (07-07-2010), Willie T (11-03-2010)
Old 07-07-2010, 07:55 PM   #20
So when did you move from MS to Florida?
What is skip trowel cedy Drywall 43 01-27-2008 01:47 PM
Texture Joewho Painting & Finish Work 8 11-06-2006 08:25 PM
Drywall repair - texture matching help build4Him Drywall 2 05-29-2006 09:50 AM
Advice on estimating skip trowel texture saucedo80 General Discussion 4 09-09-2005 07:15 PM
Advice on estimating skip trowel texture saucedo80 Drywall 2 09-08-2005 09:55 AM
