How In The World Do I Fill This One Up?! - Drywall - Contractor Talk
Old 08-29-2017, 08:14 AM   #1
Blue&White's Avatar
Trade: General
Rewards Points: 4
Hi everyone!
Had to remove a wall in an old lath&plaster house. the gaps are quite big to say the least. The one in the picture going to be under the backslash and cabinets but other spots will be exposed...
I was thinking filling with thinset mortar (tile adheseve) since it seems stronger than setting compound and then mud over it. How about foam?
I would really appreciate some advise. Thanks!
Blue&White is offline
Old 08-29-2017, 08:19 AM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,927
Re: How In The World Do I Fill This One Up?!
Drywall strips, durabond, easysand, etc.
MarkJames is offline
The Following 3 Users Say Thank You to MarkJames For This Useful Post:
Blue&White (08-30-2017), Bummie (08-31-2017), hdavis (08-29-2017)
Old 08-29-2017, 09:43 AM   #3
VinylHanger's Avatar
Rewards Points: 8,180
Really? This is a question you need to ask? Why would you use foam?
Anyway, fill it with drywall, mud, tape, skim and sand. Easy.
VinylHanger is offline
The Following 2 Users Say Thank You to VinylHanger For This Useful Post:
Old 08-29-2017, 03:34 PM   #4
Big Shoe's Avatar
Rewards Points: 1,880
Just rip out that section on the left. Pad out stud and hang new board to plane out. It will be easier in the long run.
Sent from my iPad using Tapatalk
Expect the Unexpected
Big Shoe is offline
The Following 2 Users Say Thank You to Big Shoe For This Useful Post:
Blue&White (08-30-2017), Sir Mixalot (08-29-2017)
Old 08-29-2017, 05:46 PM   #5
Faltriwall's Avatar
Trade: Drywall
Rewards Points: 8
Like was already said, add drywall board until flush or just shy of flush, then paper tape and fill with quick set (easy sand or equivalent)
Faltriwall is offline
The Following User Says Thank You to Faltriwall For This Useful Post:
Old 08-29-2017, 07:41 PM   #6
Mordekyle's Avatar
Rewards Points: 3,738
1/2" + 1/4"?
Mordekyle is online now
The Following User Says Thank You to Mordekyle For This Useful Post:
Old 08-29-2017, 07:51 PM   #7
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,008
Fill the void with dw and apply Fiba Fuse Fabric
The first one is the newer product --- like spun fiberglass - like Fiba Fuse dw tape. This is an excellent product..
The second is more like conventional fiberglass mesh.
Steve
We Fix Houses is online now
The Following User Says Thank You to We Fix Houses For This Useful Post:
Old 08-29-2017, 11:57 PM   #8
avenge's Avatar
Rewards Points: 3,132
This place needs to renamed to DIY but I wanna be a Contractor Talk.
avenge is online now
Old 08-30-2017, 12:23 AM   #9
Frank Castle's Avatar
Rewards Points: 188
True Dat!
But,
Every profession has their "Frank Burns".
How do the old sayings go?
"The only dumb question, is the one not asked"
"There are no dumb questions - Only dumb mistakes from not asking any questions"
Adapt, Improvise, Overcome.
Frank Castle is online now
The Following User Says Thank You to Frank Castle For This Useful Post:
Old 08-30-2017, 12:47 AM   #10
rblakes1's Avatar
Rewards Points: 1,944
I prefer "there are no stupid questions, but there are a lot of inquisitive idiots"
Sent from my SM-N910V using Tapatalk
rblakes1 is online now
The Following 4 Users Say Thank You to rblakes1 For This Useful Post:
avenge (08-30-2017), Californiadecks (08-30-2017), Frank Castle (08-30-2017), SmallTownGuy (08-30-2017)
Old 08-31-2017, 04:25 AM   #11
builditguy's Avatar
Rewards Points: 428
You already have your answer. #2. It will work.
As for foam, I see foam used for holes when there is skim coat plaster applied. It works. You can fill up old outlets, old light fixtures, anywhere there isn't any board and you want to fill the hole.
Here is why you can't use it on drywall. You fill the hole foam. Hopefully window and door foam. It doesn't expand as much. You wait a day, then trim off the excess. Cover it with tape. Preferably fibafuse and not mesh, but that may be a personal opinion. Tape and finish just like any other patch. Everything looks perfect.
Then, a week later, you notice a slight bulge in the drywall, the exact same shape as where you put foam. The foam isn't dry in 1 day. It feels dry. It looks dry. It's not. The foam has continued to expand for the last week. A small amount, less than 1/8", but it has expanded and caused a bulge in the drywall. Then you tear it out and re-do it.
It works under skim coat plaster (veneer plaster) because the plaster is harder and won't bulge.
builditguy is offline
The Following User Says Thank You to builditguy For This Useful Post:
Blue&White (09-01-2017)
Deep fill under garage slab lazerguy Masonry 25 08-06-2014 08:37 AM
Patio & spa pad over fill questions deckman22 Concrete & Paving 4 01-27-2008 06:14 PM
Slab on Grade fill options? James Ellis Construction 10 10-24-2006 12:55 AM
