Trade: remodelling
How To Tape 1/4" Gap In Dry Wall Repair
I have this 1/4" or about gap after installing 1x1' patch in the ceiling, I didn't have a tape so just put compound (it also screwed to the wood installed from the back and holds firmly), then in 24 hrs it cracked, I cleaned crack and applied another coat this time it's thin enough. Do you think it will say crack free, is there any time after which you can make sure that crack won't come back.
Is there any other methods to do it without tape, heard that you can put Alex to fill big cave. Also: what sand paper I have to use to finish ceiling for flat paint (no texture). From different guys have range 100 - 200. Lowes' guys don't know this at all. I'm doing first sanding now with 100 and looks not bad. Tx Dai Last edited by dainova; 04-29-2008 at 04:40 AM. |
#2 | |
Handle It!
Re: How To Tape 1/4" Gap In Dry Wall RepairQuote:
You say that you did not have time but you found the time to "Clean out the crack" and re-mud...................
#3 | |
If you used ready mix compound it will keep cracking everytime the seasons change. Dig it out and get some Durabond 90 in the brown bags, mix it up thick and pack the gap with it, let it set up and then shave any high spots and hit it again if needed. this stuff wont crack on you, as for sanding use 80 grit paper, other wise you'll be sanding for awhile. good luck
www.frankawitz.net |
#5 | |
Commercial Contractor
It cracked cause you didn't use any tape dumba**. There was no bonding.
1.You don't need to cut out your already applied spackle, in-filling the gap is a GOOD thing.. 2.BUY A DAMN ROLL OF TAPE (it won't break your bank account, even in this current economy).... 3.Tape, Block, Skim, Sand It's not brain surgery, if it feels like it...get another profession. Sorry to be rude, but it's so elementary. Even if your not a finisher, any contractor thats done interior work should/does know that.
Trade: Handyman,Doors,Carpentry
If i'm reading your post correctly, you are talking about a 1' X 1' patch.The best thing to do is remove what you did and start over ,this time make sure you measure correctly and don't have a gap.
Once you screw in the new piece then it's time for tape and compound.There is probably some basic information on the Home Depot or Lowes sites that can help you or just do a search. Good Luck. |
Trade: remodelling
Tx a lot to all who helped me with good advice
and didn't try to put my face into mud like first guys did. Yes it works really well now, I learned that it takes a heck of patience to find all these small places to put compound after I removed pop-corn. Guys what grit of sand paper you're using for finishing ceiling, for flat paint (no texture) Tx again Dai |
Handle It!
The only Qualm that I have concerns your status. You are NOT A CONTRACTOR or in a related trade. Obvious. There is a DIY forum that will serve you better. Without the caustic responses such as mine!
#9 | |
Dave |
Mod / ArchiBuilder
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs. Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/ We apologize for any inconvenience that this may have caused. This thread has been closed.
Tulsa's Leader in Outdoor Living Construction | Facebook | Tulsa Pergola Builder | Tulsa Outdoor Kitchens |
| No tape where wall meets the ceiling???? | Mike Finley | Drywall | 22 | 01-31-2012 05:52 PM |
| Help. Self Adhesive paper tape problem. | jstrand23 | Drywall | 1 | 11-28-2007 02:09 PM |
| 18 inch rollers and Tape Question | dwbrooks | Painting & Finish Work | 52 | 09-08-2006 09:22 AM |
| Low (12" or so) brick garden wall questions | bindersbee | Masonry | 8 | 04-27-2006 08:31 PM |
| Interior concrete wall repair | RCPainting | Painting & Finish Work | 6 | 03-05-2006 01:11 PM |
