Trade: Outdoor D/B
How To Rock Around Drain Pipe That Stick Out 1/4in From Stud?
My parents are remodeling there kitchen. Lots of pipes had to be moved since they tore out the soffit that was in the kitchen. When the plumber ran the new drain pipe up stairs, some how he managed to let it stick out from the stud 1/4in . This pipe is in a outside wall and there is a elbow right at the top of the wall which i think is part of the reason it pertrudes. Whats the best way to sheetrock around/over this pipe with out having a big hump in the wall? Are there any viable solutions besides shimming out the whole wall?
Thanks |
Re: How To Rock Around Drain Pipe That Stick Out 1/4in From Stud?
I'd fir out the wall...
#3 | |
Interior Remodeling
Trade: Interior Remodeling
Re: How To Rock Around Drain Pipe That Stick Out 1/4in From Stud?Quote:
Chief Toilet Mover
Trade: Bathroom Remodeling
Sounds like a double layer or dywall will solve the problem to me if you don't want to or can't move the pipe 1/4" which would be my first choice. Actually my first choice would be to have the plumber come back and move it 1/4 inch or tell me why he couldn't. Actually my first choice before that would be - how is this passing code?
Custom Builder
Another option, eat a qtr out of the back of the drywall. Rotozip at the right depth works good for this.
Not my favorite option but works. Careful with the hang. Bob
Bob |
Chief Toilet Mover
So what happens when Ma ruskent decides to hang her "Home Sweet Home" picture right over that drain pipe in the wall and has Pa ruskent drive a nail right into it?
Custom Builder
Then they get a free economy periodic water fountain.
Bob
Bob |
Drywaller for Hire
Trade: Drywall/Interior Finish
ummm....get that freakin plumber back in there to rework the stack!
~a HAVE TOOLS, WILL TRAVEL |
carpenter and builder
Trade: carpenter and builder
Maybe the old size 10 boot trick might work. Either on the stack or the plumbers backside !
Dont give me problems, give me solutions. |
Trade: gc
it may not be the plumbers fault.. it sounds like its a plumbing stack that is probably 3" inside 2x4 walls.. its bound to stick out a tad.. if its really bad id make sure its 100% centered in the wall cavity.. before you drywall over it.. if its centered between both sides of the 2x4 you should be able to hang right over it
Been there,
If it is only a 1/4 inch, I totally agree with Glasshouse concept. I had to do this in a victorian style remodel on an ocean front - with very picky owners (Fortunately, they were friends of mine) Tho, I'm surprised that they are still married after that remodeling. Anyway: Attach the sheetrock as close as you can to the pipe on each side, you can actually leave the pipe slightly exposed. Then, tape right over the pipe and the whole area...and skim it all over nice and smooth. It will work. Did it in 2 areas of the kitchen (Ceiling and wall). -Build Well - Last edited by AtlanticWBConst; 04-26-2006 at 08:47 PM. |
Trade: Residential home construction
Just had the same problem in last two houses. One we spanned with drywall. It was noticeable to the trained eye, but passed the normal observation. I wouldn't leave it with a customer who is detail oriented or one who wants crown molding or different paint colors ceiling and walls. The other was a short wall that we firred out with 1" x 2". Easy fix and it solves the problem. Not always the plumbers fault 3" stack in a 3 1/2" wall with fittings doesn't always fit real well.
| Drain Pipe | denick | Excavation & Site Work | 18 | 07-12-2009 04:41 PM |
| drain pipe holes up or down? | jimb317 | Plumbing | 9 | 06-06-2007 04:22 PM |
| black drain pipe?? | pauls painting | Plumbing | 5 | 01-08-2007 11:29 AM |
| Ace Duraflow vs PVC Drain Line Repiping to Replace Cast Iron Drain Pipe | TDELC | Plumbing | 0 | 10-16-2006 03:31 PM |
| Drain Pan doesn't have a drain pipe? | Neil_K | HVAC | 6 | 05-09-2005 01:14 PM |
