How Much To Charge For Level 5 Finish Vs Level4
Old 10-17-2008, 06:58 PM   #1
Profit is not dirty.
AARC Drywall's Avatar
Trade: Residential Drywall and Taping
Rewards Points: 266
Hell all....i keep getting asked to prime walls...I dont mind doing it, but customers seem to get a little upset when i tell them it will cost extra..
Just out of curiousity how much extra does everyone else charge?
I tend to go by the hour...maksing etc and materials...its around $100/ hr.
J
Profit is NOT a dirty word....Cheap is....
AARC Drywall is offline
Old 10-17-2008, 07:17 PM   #2
DavidC
DavidC's Avatar
Rewards Points: 2,006
Re: How Much To Charge For Level 5 Finish Vs Level4
The charge would be the difference in time times your rate plus materials and markup.
Instead of telling them it will cost extra try saying sure thing, no problem. We do that all the time. Then just quote the right price.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 10-17-2008, 07:44 PM   #3
Rewards Points: 266
usually its after the quote is given...we prime the celings before we textrue..so they figure it would be no cost to prime the walls as well...
J
Old 10-17-2008, 09:29 PM   #4
DavidC
DavidC's Avatar
You could make it a matter of policy to offer it as an option for $XX in every proposal going forward. Many people will thank you for thinking of it and initial their OK on the line provided. Or have them initial the no thank you line. Either way it is settled before you start.
I do this on occassion and it can either save a headache or add to your bottom line. A good example is when they tell me they will move the furniture before we start. There will be an option to have us do it with a disclaimer and a set charge. They can approve or decline, but they must to one or the other. So when we show up and "they didn't have time" there is no doubt about the extra charge.
Good Luck
DavidC is offline
Old 10-18-2008, 08:37 AM   #5
Al Taper's Avatar
Trade: Interior Commercial Contractor
Rewards Points: 250
Paint prime or skim coat.(by hand or sprayer)????
Al Taper is offline
Old 10-19-2008, 10:23 AM   #6
Rewards Points: 266
i spray it on and then back roll it ...
Old 10-20-2008, 10:28 AM   #7
Adam in BC's Avatar
Trade: Drywall Contractor
Rewards Points: 25
I charge between 22 and 30 cents a foot for primer (materials included)
And for level 5 i use the synk pre coat thats usually between 25 and 35,
I charge more for the level 5 because it needs sanding afterwards.
Adam in BC is offline
Old 10-22-2008, 04:32 PM   #8
Tapingfool's Avatar
Trade: spackler--for life it seems like I can never get away from it as there is always work somewhere!!
Rewards Points: 75
I just charge what I want depending on the type and time it takes. when I talk to some people they have no idea there is even different finish levels. I just got done skim coating a room and charging an additional third!! good and easy $$$
Tapingfool is offline
Old 10-23-2008, 11:12 PM   #9
Rewards Points: 266
Thanks guys...it gives me a better idea...anyone tried the synko tips primer? its expensive but seems to bite into already painted walls...worked good for me..anyone else.
J
How much to charge for new stairs skarrlette Finish Carpentry 40 12-14-2010 04:38 PM
Level 5 finish?? beapainter Drywall 3 09-29-2008 05:12 PM
Finish Carpenter/Cabinet installers/General Construction JMFWood Help Wanted or Looking For Work 2 09-15-2008 10:45 AM
Matching sand finish? Thewallfixer Painting & Finish Work 11 07-13-2007 11:08 PM
Screen Sanding & Moisture Cure Finish plazaman Flooring 3 01-28-2007 01:40 PM
