How To Attach Drywall To Brick Wall
Old 01-25-2008, 02:29 PM   #1
Mwcop1's Avatar
Hi,
I am doing a bid for an old warehouse/store in Inglewood, CA. The owner wants all walls drywalled. The existing walls are exposed brick. How would this be done?
Thanks for any help.
Mwcop1 is offline
Old 01-25-2008, 04:21 PM   #2
Thom
thom's Avatar
Re: How To Attach Drywall To Brick Wall
concrete nail 1X2's or 2X2's into the mortar joints.
thom is offline
Old 01-25-2008, 04:25 PM   #3
Renovation Professional
savant's Avatar
Trade: My pudding for your brownies
Or, curtain wall it with 2x2 steel stud & track. (no messing around with shims & wavy brickwork)
Don't rush a miracle-man. If you rush a miracle-man, you get rotten miracles.
http://www.refined-home.com
savant is offline
Old 01-25-2008, 06:02 PM   #4
Tony M's Avatar
Trade: Drylining
Dot & dab it.
Tony M is offline
Old 01-25-2008, 06:04 PM   #5
Average Joe
Heritage's Avatar
Trade: D/B, Management, Consulting, Contracting.
If you're going to go wood nailed/screwed into mortar go for the 2*2's. Savant's idea would make sure it's straighter.
If it's a hack job you can even go PL directly onto brick, 1/2" dry. I have done a lot of stucco wall cover ups with 1/4" but brick is too inconsistent.
There you have the good, the bad and the ugly
Toronto General Contractor-Renovation Blog-Contractor on Facebook-Renovation on twitter-Contractor Youtube
Originally Posted by rex View Post
i get high with my left hand.....
Heritage is offline
Old 01-25-2008, 07:44 PM   #6
Drywall Swine's Avatar
Trade: I own a drywall company
maybe try hatbar if the brick wall is thick enough. Just a thought.
Drywall Swine is offline
Old 01-25-2008, 09:28 PM   #7
BUTCHERMAN's Avatar
Trade: DRYWALL PROFESSIONAL
load the brick with titebond heavy duty construction adhesive.secure with 1 1/2 hilti shots with washer. use #3 loads
BUTCHERMAN is offline
Old 01-25-2008, 10:03 PM   #8
Al Smith
A W Smith's Avatar
hat channel and loads
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 01-29-2008, 02:06 AM   #9
Raven
raven2006's Avatar
Trade: drywall finishing and texture ceilings
Tony....I was at this job site a couple weeks ago where the drywallers had this same problem. Right away the fellow from england suggested the dot&dab method, which is obviously popular over there. But not being sure of where to get the dot&dap mud here they asked to use some of my multi-purpose drywall mud, which as I predicted, was in no way capable of holding up a 14 foot high piece of drywall! So what kind of mud/adheisive is normally used for this method?
raven2006 is offline
Old 01-29-2008, 08:27 AM   #10
Frankawitz's Avatar
Metal ribbed lath nail to the brick then Portland cement, sand and then mix your plaster and skim the wall done deal about two days work.
Frankawitz is offline
Old 01-29-2008, 05:41 PM   #11
Tony M's Avatar
Trade: Drylining
In the UK, the adhesive is referred to as either Bonding compound, or Drywall adhesive. It is very sticky, and sets extremely hard. It is also very brittle.
http://www.british-gypsum.bpb.co.uk/..._adhesive.aspx
Tony M is offline
Old 01-29-2008, 09:53 PM   #12
Tim0282's Avatar
Trade: drywall contractor
Would you leave it smooth or float the finish?
Tim0282 is offline
Old 01-30-2008, 08:33 AM   #13
Frankawitz's Avatar
finish is always smooth
Old 01-30-2008, 09:30 AM   #14
dlcj's Avatar
Trade: home builder carpenter Central Alabama
Id build a 2x4 curtain wall and up sell them on more insullation. If there concerned with loosing 4" of space (per wall) then go with Frankawitz idea.
dlcj is offline
Old 02-07-2008, 07:33 PM   #15
plazaman's Avatar
any of above stated methods, we usally dab mud on the back of the drywall and press firmly. done many times, still holding after years.
plazaman is offline
Old 02-07-2008, 08:41 PM   #16
Tim0282's Avatar
Seriously, you have really used mud to attach the rock to a wall? All purpose?
Tim0282 is offline
Old 02-08-2008, 02:51 AM   #17
theblones's Avatar
Trade: plasterer
It works like a metal rop ceiling. you run 25mm track on the bottom and top and plumb and level it. you slide the f****** intermediate studs and brace em to the wall
p://www.british-gypsum.bpb.co.uk/systems/system_selector/gyplyner__universal_lining.aspx
you guy probably have this system over there and it is lighter to use, because i heard girls do the drywall over there
theblones is offline
Old 02-08-2008, 08:39 AM   #18
Al Smith
A W Smith's Avatar
Originally Posted by theblones View Post
It works like a metal rop ceiling. you run 25mm track on the bottom and top and plumb and level it. you slide the intermediate studs and brace em to the wall
sod that
Al Smith
Old 02-08-2008, 08:04 PM   #19
plazaman's Avatar
yes all purpose, holds strong as hell believe it or not.
plazaman is offline
Old 02-08-2008, 08:19 PM   #20
theblones's Avatar
Trade: plasterer
abso****in
no way will mud hold a board to the wall.
i have seen a foam in a can that will do it and you get about 9 boards a can. its like spray foam, they keep saying they want to make it easier and they do. its just knowone sees the change coming.
drywall on brick ODDBALLS Drywall 1 09-26-2007 09:12 AM
Brick wall Harry I Electrical 18 04-05-2007 04:04 PM
Best way to hang drywall on concrete wall?? gche37 Drywall 10 11-30-2006 10:29 PM
drywall over interior plaster/ brick walls n8sr Drywall 10 11-10-2005 10:18 PM
