Help.. Wet Banjo Or Dry Banjo
Old 12-22-2008, 08:28 PM   #1
BigF350's Avatar
Trade: Construction
How's it going! I'm looking into buying a Banjo but not sure which one I should buy. I don't do a bunch of drywall but I thought it would be nice for when I do, to make it faster than what I usually do. The store that I went to said to get the wet banjo. What is the difference. As you can tell, they did not help much. I know that one has a separation between the tap and mud, and the other does not. Help.. Any input would be great. Thank
BigF350 is offline
Old 12-22-2008, 08:50 PM   #2
precisionbuild's Avatar
Trade: Contractor
Re: Help.. Wet Banjo Or Dry Banjo
Neither.
But if you insist...wet.
I'd give you mine if you lived nearby.
If you're trying to pick up speed taping, get a bazooka.
precisionbuild is offline
Old 12-22-2008, 08:58 PM   #3
BigF350's Avatar
Trade: Construction
Thought about it, but I don't do that much drywall. Thanks
BigF350 is offline
Old 12-22-2008, 09:55 PM   #4
Tim0282's Avatar
Trade: drywall contractor
Doesn't the wet banjo put the mud on both sides of the tape? Messy... I used to use the dry. Haven't used one except fire taping in attics. Bazooka is more consistent, but I understand the cost. I would lean to the dry banjo.
Tim0282 is offline
Old 12-23-2008, 08:25 AM   #5
Capt-Sheetrock's Avatar
Trade: Drywall
Get the dry tape, no-one uses a wet anymore. The wet is messy as heck and if you stop for awhile, you will have to remove the tape thats left and start over, it gets soaked. I used one for years before I got a bazooka, the guy that taught me, used a wet, he suggested I get a dry, which I did, he also switched to a dry tape. To sum it up, anyone that uses a wet tape banjo will switch to a dry tape banjo, so save yourself the hassle and exspense and just start with a dry tape.
I prefer the Marshal town, check with all-wall for the best prices imo
Capt-Sheetrock is offline
Old 12-23-2008, 09:50 AM   #6
BigF350's Avatar
Trade: Construction
Thanks for the input.
BigF350 is offline
Old 12-23-2008, 02:00 PM   #7
Darren@Partners
Darren@Partners's Avatar
Trade: Drywall Contractor
By wet I guess you mean a water bath-type. No one uses those anymore (that I know of). We use a "Denver" style -- has top handle & strap on side for your right hand. Puts the weight closer to your body than one w/ top handle only. Be sure to load proper w/ tape on TOP of mud inside. Maybe overstating the obvious, but just last week GC's laborers firetaped behind my hangers & he loaded his wrong and had mud on wrong side of tape. Probably didn't matter but was really messy and slow. Check your local pawn shops before you give new price.
Darren@Partners is offline
Super taper or Banjo? steve336 Drywall 24 03-27-2009 01:25 AM
Banjo VS Bazooka ?????????? Dougmt Drywall 8 11-02-2008 05:50 PM
Banjo Help Worm Drive Drywall 20 03-18-2008 07:44 PM
Question?? Just take a look. bujaly General Discussion 35 02-28-2008 05:45 PM
Should I buy a Banjo? dayspring Drywall 43 09-03-2006 09:54 PM
