Has Anyone?
Old 01-27-2009, 04:50 PM   #1
Al Taper's Avatar
Trade: Drywall Finishing
Has Anyone?
Some one told me a few months back that they took their coating box. And cut a hole in the back and make their own apla-tech. Has anyone hear of this or tryed it?
Al Taper is offline
Old 01-27-2009, 06:12 PM   #2
Tony M's Avatar
Trade: Drylining
Re: Has Anyone?
Yes mate. Obviously you will need the Apla-tech cfs box handle, and just drill a hole around 1/2 inch in the box lid, central to the handle. You can still use the box with a normal handle as the hole is covered, isn't it? I got ann engineer friend of mine to make up some shims that screwed to the inside of the box, utilising the little stop screws, which reduced the travel on the box to about an inch, to keep the weight down. This still allowed you to push if you needed to.
Tony M is offline
Old 01-27-2009, 06:28 PM   #3
Rx8's Avatar
Trade: Drywall Finisher
Send a message via AIM to Rx8
Re: Has Anyone?
sounds nuckin futs to me.
Rx8 is offline
Old 01-27-2009, 06:45 PM   #4
Al Taper's Avatar
Re: Has Anyone?
Does it work well?
Al Taper is offline
Old 01-27-2009, 08:01 PM   #5
A+ Texture's Avatar
Trade: Drywall, Modulars, Remodeling
Re: Has Anyone?
Hey Al, I think I came across a couple threads on drywalltalk.com, this sites sister site. I think a guy was saying he had his tapetech boxes rigged like that.
A+ Texture is offline
Old 01-27-2009, 09:22 PM   #6
Al Taper's Avatar
Re: Has Anyone?
Have to look around for it over there. thanks
Al Taper is offline
Old 01-28-2009, 02:30 PM   #7
Tony M's Avatar
Trade: Drylining
Re: Has Anyone?
Originally Posted by Al Taper View Post
Does it work well?
Of course it does. I wouldn't use it if it was pissing out everywhere.
Tony M is offline
Old 01-28-2009, 06:18 PM   #8
Al Taper's Avatar
Re: Has Anyone?
When you use the paint pump is the mud more wetter then when you use a hand pump?
Al Taper is offline
Old 01-29-2009, 01:29 PM   #9
Tony M's Avatar
Trade: Drylining
Re: Has Anyone?
No it isn't, because the airless is that powerful it can handle it ok.
Tony M is offline
Old 01-29-2009, 02:18 PM   #10
A+ Texture's Avatar
Re: Has Anyone?
Can this be done without a mark iv, or v. Or without the actual big apla tech deal. I have a rtx 1500, and a xr9 paint sprayer, could I rig either one of these somehow?
Old 01-29-2009, 03:22 PM   #11
Tony M's Avatar
Trade: Drylining
Re: Has Anyone?
Your RTX pumps at 100psi. The big airless pumps are pushing out nearly 3000. you need high pressure and through volume to keep the boxes full and push out enough material.
Tony M is offline
