#81 |
General Contractor
Trade: General Building Contractor
Re: Hanging Methods, Screws Vs. Glue
For me, the ONLY book that matters is the Code book. Obviously, in Canada the code allows you to glue, here in the States you can but only in conjunction with traditional fasteners and only with significantly more fasteners than the pro-adhesive advocates apparently use.
I can read and I have read the book(s). |
#82 |
I disagree with that statement. The code is the absolute minimum applicable standard. A true professional understands this and whenever feasible will try to exceed the code requirements.
One should also always be willing to try and improve the methods they use in order to provide a better end product and increase productivity. Reading about other methods used by various tradesman is a very inexpensive way to learn what works, what may not work, and what may be cost prohibitive. |
#83 | |
General Contractor
Re: Hanging Methods, Screws Vs. GlueQuote:
#84 |
Trade: Handyman
Glue or not, when it comes time for the screw inspection down here, esp. on commercial work, one every other stud/joist/whatever will get you red tagged.
Give me my SuperDrive and a box of screws. |
#85 |
Profit is not dirty.
Trade: Residential Drywall and Taping
[quote=Capt-Sheetrock;808680]Glue is way better???? in your opinion
Glue is faster??? yeah, in your mind your a legend Don't know bout you, but i am in the drywall buss to make a living If you think that glue is faster, you have obviously never seen professional drywall hangers at work Glue has no differance on finisher speed,,,( maybe 30 mins over 300 boards) Glue is the next level????? Level of what, ,,,,perhaps, "how can I slow myself down, cost myself money, on something that absolutely nobody but other hangers give a rip about!!!! Glue is faster....i have proven it, several times...I thought the same that glue was slower, but ....its not. Glue on walls does increase the finishing speed...anyone can see that... lets put it this way... on a 10' wall you will have lets say 28 screws to coat 3 times... on the same size wall but glue'd you have 2-4 max...do the math Keep in mind that this is only on one wall you still have to coat the rest of the walls in the house. Glue has no differance on finisher speed,,,( maybe 30 mins over 300 boards) you just admitted that glue is faster...30 min over 300 for a single coat. times that by 3 for 3 coats....let me see when i went to school that was 30+30+30= 90 min...of time saving....which = free money. also do you still run corded guns, and keyhole out box's or have you evolved to cordless and rotozips?
Profit is NOT a dirty word....Cheap is.... |
#86 | |
100% correct the code book is a min standard...and any good contractor of any sort will not go below the code. Here in BC we do not have drywall inspection, sometimes i think that we should to get rid of the fly by nighters.....the inspectors here in pg, only enforse the codes min standard, and unfortunately some of them have no clue what they are talking about at the best of times. When this happens the enginere will over rule their desisions.
#87 |
According to IRC Table R702.3.5 drywall installed with adhesive must have a maximum fastener spacing of 12" to 16" on ceilings and 16" to 24" on walls depending on board orientation and fasteners used. This does not equate out to 2 to 4 fasteners per sheet max. Type X in garages beneath habitable rooms installed perpendicular to the framing (required) requires fastening 6" o.c.
| Deck Screws vs Joist Nails | subybohn | Decks & Fencing | 100 | 11-25-2009 03:52 PM |
| Slotted screws and other peeves! | WNYcarpenter | General Discussion | 31 | 10-10-2009 12:30 PM |
| Help with some various Installation Methods | AcademyHardwood | Flooring | 2 | 08-18-2009 07:46 PM |
| Removing glue after pulling paper is easy! | MZ-HANDYMAN | Wallpaper | 20 | 08-06-2009 04:32 PM |
| Hanging a floating vanity | Gus Dering | Finish Carpentry | 28 | 05-08-2009 10:22 PM |
